1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: AW: [Fwd: Re: Explicit initializing of Sub-Record]
To: [email protected]
Date: Wed, 21 May 2003 15:50:34 +0200
Hi Ben
Thanks for your answering. The 2'nd proposal I had already implemented but it isn't really a nice programming because each time when the IO Intr. triggered subroutine was called the flag has always been checked before. It may be able to influence the system load, depending on the cycle-time of the EPICS queue in fact. The first point seems more for a compliant solution for further efforts.
Regards George
-------- Ursprüngliche Nachricht --------
Betreff:
Datum:
Tue, 20 May 2003 15:22:35 +0200
Von:
Benjamin Franksen <[email protected]>
Firma:
BESSY
An:
[email protected]
Referenzen:
[email protected]"><[email protected]>
Joerg Kuehne wrote:
> Did anyone know how I could explicit decide an initializing of a
> sub-record?
The subRecord does not provide for this. In the record support, the
address of the routine whose name is given in field INAM is thrown away
after init_record has executed it. There are two obvious solutions to
your problem:
1) Create an enhanced version of the subRecord which saves the init
routine's address and executes it under certain conditions.
2) Write your subroutine so that it calls the record's init routine,
depending on the value of some of the input fields.
Ben
Prev: Re: Timezone Dirk Zimoch
Next: Re: Timezone Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS collaboration meeting registration Hayton, TG (Tim)
Next: [no subject] l7a
