> From: "Lifang Zheng" <[email protected]>
> Hi everyone,
> We are developing 100MeV LINAC vacuum control system through RS232 serial. The
hardware has a VIPC616 carrier and an IP-Octal-232. The software includes
drvSerial,drvAscii,drvIpac,drvVipc616, tyGSOctal and devAscii. The first test
was successfully with the help of Allan Honey and Steven Hartman a few month
ago.
> But we have one problem. Some of the commands use the format d.ddde-dd, but
the OUT field of AO have to be specified as %e instead of %9.3e or %.3e. So the
value of AO will be sent as d.ddd000e-dd which doesn't meet our requirement.
> Does somebody meet the same problem? Is there any solution?
> Any suggestion is welcome,
> Lifang
Aloha
Hopefully, the following will help.
The following excerpt is from the modification history in the header of
devAscii.c (there is an example of a simple checksum protocol at the bottom of
drvAscii.c)
* 4. User-specified framing routines can be specified.
* With this release one can create their own input and output
* framing routines and have them override the default getFrame()
* and putFrame() routines. This allows one to do more sophisticated
* packet framing (e.g. a simple checksum could be added/checked).
* To specify special framing routines one must download the library,
* they created, containing those routines, then register the
* functions with drvAsciiSetTxFunc() and drvAsciiSetRxFunc(), all
* prior to iocInit. Note that a different set of framing routines
* can be registered for each serial link. Also note that there are
* special requirements imposed on the framing routines. An example
* exists within drvAscii.c
Of course the output routine would be called after the incorrect real format is
embedded in the command string (for Lifang's case) so it will be a bit messy to
undo that.
Alternatively, you could hack processFormat() in drvAscii.c
Look for
while ( isdigit( *spec ) ) {
This needs to be modified to accept '.'
In the current state this '%ne' is valid but '%n.me' is not.
I will work towards modifying drvAscii so that it accepts numeric format specs
(i.e. '%n.me' rather than just '%e' - not this week though). When the new
release is available you should only need to modify your startup script to
remove the use of your own format routines, assuming you go that route.
AH
RE: the command formats in RS232 Geng, Xiaosong
Specifications for the JLab archiver machine Matt Bickley
<2003>
2025
2026
EPICS 3.14.2 Under Windows Cox, G (Graham)
<2003>
2025
2026
