1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: newport mm4000 motor record hardware(gpib/serial) needs
To: TECHTALK <[email protected]>
Date: Fri, 12 Dec 2003 12:50:21 -0500
What's the hardware requirements for Newport MM4000/3000 to work under motor record? Currently we have mm3000/4000 work with SPEC/gpib (pci card under linux). We'd like to have a VME gpib or serial card and put MM4000/3000 in motor record.
My question is: What kind of VME gpib/serial card should I get? We have vxWorks 5.3 (BSP mvme-2304, ppc604) and I was able to built epics3.13.9 on it (using the Linux cross compiler from sns).
From motor record (motor4-7-4) src, it seems it needs mpf-gpib (which supports SBS IP-488) or mpf-serial (SBS OctalUART serial IP module). But then Mark Rivers MM4000 site (http://cars9.uchicago.edu/software/epics/dev_mm4000.html) says it also works with NI-1014.
Can some one who has used it provide some detail on the hardware it needs?
Thanks!
Zhijian Yin NSLS, [email protected]
Prev: RE: Spurious link alarms generated? J. Frederick Bartlett
Next: RE: newport mm4000 motor record hardware(gpib/serial) needs Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Insertion Devices Control and EPICS Allan Honey
