1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Insertion Devices Control and EPICS
To: [email protected]
Date: Fri, 12 Dec 2003 09:52:55 -1000 (HST)
> Date: Fri, 12 Dec 2003 08:42:33 -1000 (HST)
> From: Nick Rees <[email protected]>
> X-X-Sender: npr@mahina
> MIME-Version: 1.0
> List-Help: <http://www.aps.anl.gov/epics/tech-talk/index.php>
> On Fri, 12 Dec 2003, Rok Sabjan wrote:
> > First let me remind everyone on the problem. We have two (or more)
> > motors which we would like to move synchronously. This means to
> > guarantee the movement will start and end at the same time. This is
> > extremely important when changing the gap of an insertion device.
> We don't make much use of the OMS system - we tend to use serial line
> motor controllers (but they are starting to come with ethernet addresses
> as well). Typically we separate setting the next demand and the move
> command into separate instructions. If we set demands on multiple axes
> before a move instruction the axes move synchronously under hardware
> control.  Otherwise the moves are (of course) asynchronous.
> Just a thought.
> Nick Rees
Just to expound upon Nick's thoughts a little.
There are some of the serial motor controllers that use RS-485,
thereby allowing a 'star' interconnection configuration. Some
of those controllers also allow commands that are not targeted
to a specific controller to be acted upon by all controllers. This
provides very close synchronization of motion, assuming the update
rate is not too high. I assume this is also true for controllers
that are connected to ethernet, albeit, I have not researched that
at all.
Also, in my opinion, for many applications the PMAC solution is overkill!
We use many PMACs with the KECK interferometer, in a lot of cases they
are used for discrete positioning of optical elements (not tracking).
All for the sake of consistency?
AH
Prev: Re: Insertion Devices Control and EPICS Nick Rees
Next: Re: Insertion Devices Control and EPICS Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Insertion Devices Control and EPICS Mark Rivers
Next: newport mm4000 motor record hardware(gpib/serial) needs Zhijian Yin
