1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Insertion Devices Control and EPICS
To: [email protected]
Date: Fri, 12 Dec 2003 08:42:33 -1000 (HST)
On Fri, 12 Dec 2003, Rok Sabjan wrote:
> First let me remind everyone on the problem. We have two (or more)
> motors which we would like to move synchronously. This means to
> guarantee the movement will start and end at the same time. This is
> extremely important when changing the gap of an insertion device.
We don't make much use of the OMS system - we tend to use serial line
motor controllers (but they are starting to come with ethernet addresses
as well). Typically we separate setting the next demand and the move
command into separate instructions. If we set demands on multiple axes
before a move instruction the axes move synchronously under hardware
control.  Otherwise the moves are (of course) asynchronous.
Just a thought.
Nick Rees
Head of Software and Computing Services
Joint Astronomy Centre                   Ph:         +1 (808) 961-3756
660 N. Aohoku Place                      Fax:        +1 (808) 961-6516
Hilo, HI.  96720                         Email: [email protected]
Insertion Devices Control and EPICS Rok Sabjan
Prev: RE: newport mm4000 motor record hardware(gpib/serial) needs Mark Rivers
Next: Re: Insertion Devices Control and EPICS Allan Honey
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Insertion Devices Control and EPICS Oleg A. Makarov
Next: Re: Insertion Devices Control and EPICS Tim Mooney
