1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: newport mm4000 motor record hardware(gpib/serial) needs
To: <[email protected]>, "TECHTALK" <[email protected]>
Date: Fri, 12 Dec 2003 12:33:27 -0600
> What's the hardware requirements for Newport MM4000/3000 to
> work under motor record?  Currently we have mm3000/4000 work with
SPEC/gpib (pci
> card under linux).  We'd like to have a VME gpib or serial
> card and put MM4000/3000 in motor record.
> My question is: What kind of VME gpib/serial card should I
> get?  We have vxWorks 5.3 (BSP mvme-2304, ppc604) and I was able to
built
> epics3.13.9 on it (using the Linux cross compiler from sns).
Under EPICS 3.14.4 it works with mpfSerial.  mpfSerial talks to Unix,
Linux and vxWorks serial ports.  On vxWorks it works with both the
serial ports on the CPU card, and with the SBS IP-Octal, through Andrew
Johnson's ipac module.  I have tested the MM4000 under both vxWorks and
Linux on 3.14.4.
Note that there is currently no support for the SBS IP-488 module under
3.14, because support has been removed from MPF, and support is not yet
provided under Marty Kraimer's asynDriver
(http://www.aps.anl.gov/epics/modules/soft/asynDriver/ )
Mark Rivers
Prev: newport mm4000 motor record hardware(gpib/serial) needs Zhijian Yin
Next: Re: Insertion Devices Control and EPICS Nick Rees
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Implementation of alarm handlers by EPICS users Munro Jr, John K.
