The reason for that behaviour is, that the Export-functions of the ChannellArchiverHi, When I tried to archive the vacuum data with ChannelArchiver, I got some data like: (every function, that formats floats/doubles into strings) honours the PREC-field of the connected PV. It's like sprintf( "%*f", prec, value ) In some cases, it would be better to use engineering- or scientific-notation instead of decimal notation - or even ignore the PREC at all. As an exception, a PREC of 0 is indeed ignored... We had the same problems with our vacuum values here at BESSY and started to store the logarithmic values instead. The good thing is: The archive has all the values with full accuracy, so once you change the formatting of the output, you'll get your values just like you expect them to be. But none of the bundled export tools ignores the PREC-field if it is set to something other than 0. The "20 seconds" problem actually isn't a problem. If a new value arrives via ChannelAccess, it is stored with the accurate timestamp. The other values are not even stored in the archive (Kay, correct me if I'm wrong). It's the output-functions again, that produce these repeated values. I know this is not really helpful, but it's an attempt to explain what happens... Is ther any guideline on whether and how to handle/honour the PREC field at all? Thomas
| ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
