On Sunday 14 March 2004 01:32, Benjamin Franksen wrote:
> ...is it possible to
> circumvent the above mentioned deadlock situation by calling
> ca_create_channel without connection handler and afterwards call
> ca_change_connection_event?
Meanwhile i found out the hard way that this is a bad idea since it opens a
race window between the two calls, so that initial connection events may be
lost. This is probably the reason why giving the connection handler in the
call to create_channel is recommended.
I also found a way to circumvent the deadlock i described (without creating an
auxilliary task only to handle this situation).
However, i am still interested in answers to my questions. Particularly, a
more specific explanation of what is meant by "...must wait for successful
status from ca_pend_io prior to using the channel for the first time" would
be helpful. In my experiments calling ca_change_connection_event without
waiting for success from ca_pend_io neither crashes the application nor
exhibits any other unexpected behavior. So, for the moment i will assume that
it means the channel may be disconnected and appropriate error codes will be
returned.
Ben
- More CA questions Benjamin Franksen
Digital filter record? Eric Norum
Re: Problems of Channel Archiver Thomas Birke
<2004>
2025
2026
RE: More CA questions Jeff Hill
<2004>
2025
2026
