1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: More CA questions
To: Techtalk <[email protected]>
Date: Sun, 14 Mar 2004 01:32:18 +0100
Hello Jeff & other CA experts,
The CA client reference manual says: "The user's connection state change
function will be run immediately from within ca_create_channel if the CA
client and the server are both hosted within the same address space (within
the same process)."
(1) From the above follows that if (for whatever reason) the connection
handler waits for an event that will happen only after ca_create_channel
completes, the application will be deadlocked. Is this also the case if CA is
used multi-threaded, i.e. initialized with the ca_enable_preemptive_callback
flag?
(2) Does a similar rule apply to ca_change_connection_event if previously
ca_create_channel was called with a NULL connection handler?
Btw, ca_change_connection_event is nowhere mentioned in the new CA client
reference. I hope it was just forgotten and is not deprecated.
(3) The manual further says: "If a connection state change call back function
is not installed when ca_create_channel is called (if a nil function pointer
is supplied) then the application program must wait for successful status
from ca_pend_io prior to using the channel for the first time."
I have some difficulty infering what "must" and "using" means in this case.
At first, i thought it means that the behavior of CA routines that take a chid
as argument is undefined if called with the chid returned from
ca_create_channel (with null connection handler) before ca_pend_io returns
success. However, this seems to contradict what is said in the description of
ca_create_channel: "The function ca_state(CHID) can be used to test the
connection state of a channel. Valid connections may be isolated from invalid
ones with this function if ca_pend_io() times out." This statement suggests
that at least ca_state seems to have a defined behavior.
So, what about calls to ca_change_connection_event? (I.e is it possible to
circumvent the above mentioned deadlock situation by calling
ca_create_channel without connection handler and afterwards call
ca_change_connection_event?)
Or am I completely wrong and all that "must" means is that the user should be
aware that certain CA routines will return an error code, saying that the
channel is disconnected??? I'm at a loss...
Ben
Re: More CA questions Benjamin Franksen
RE: More CA questions Jeff Hill
Prev: RE: rapid scans Mark Rivers
Next: Re: Allen Bradley PLC Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Allen Bradley PLC Rarback, Harvey
Next: Re: More CA questions Benjamin Franksen
