To set the historical record straight, on 14 February 2003
David H. Thompson (ORNL) posted -
> I also noticed in the record reference manual that the PUTF field is a
> logical that happens to be set if dbpf, or channel access, is writing a
> value to the record and if SCAN is passive. This lets the device
support
> know that data should be written instead of read. Scanning can be
> accomplished by using an flink from something that is scanning, say a
> fanoutRecord.
As you pointed out, the use of PUTF does not afford a
general solution and that this is only valid for a specific
combination of record linkages and CA client actions:
1. the record must be scan Passive.
2. the "write" action must be triggered by a dbPut to a field
with Process Passive set.
3. the "read" action must be triggered by a FLNK.
Is the latter condition equivalent to someone calling dbProcess()
directly?
On Fri, 9 Apr 2004, Marty Kraimer wrote:
> It is also a little scarry because it means that the original feature
> must not be changed in such a way that it breaks the new usage.
- Peregrine
Peregrine M. McGehee Department of Astronomy
New Mexico State University, Las Cruces, New Mexico
- Re: Record processing knowledge of dbAccess context Peregrine McGehee
- Re: Record processing knowledge of dbAccess context Marty Kraimer
<2004>
2025
2026
<2004>
2025
2026
