1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Record processing knowledge of dbAccess context
To: Peregrine McGehee <[email protected]>
Cc: [email protected], [email protected]
Date: Fri, 09 Apr 2004 10:24:37 -0500
Peregrine McGehee wrote:
As you pointed out, the use of PUTF does not afford a
general solution and that this is only valid for a specific
combination of record linkages and CA client actions:
1. the record must be scan Passive.
2. the "write" action must be triggered by a dbPut to a field
with Process Passive set.
This should say dbPutField, i.e. a put from outside database access. PUTF is not set if processing occured because an output DB_LINK caused dbProcess to be called.
3. the "read" action must be triggered by a FLNK.
Is the latter condition equivalent to someone calling dbProcess()
directly?
This sounds correct. But be careful when calling calling dbProcess. In particular don't call it if you are running under a scan task. When not part of a scan task it must be surrounded by dbScanLock/dbScanUnlock.
Marty
Bidirectional device support Andrew Johnson
Re: Record processing knowledge of dbAccess context Peregrine McGehee
Prev: RE: Record processing knowledge of dbAccess context Thompson, David H.
Next: Bidirectional device support Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Record processing knowledge of dbAccess context Peregrine McGehee
