1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Bidirectional device support
To: [email protected]
Date: Fri, 09 Apr 2004 15:38:27 -0500
The talk of how to implement bidirectional I/O through existing record types still has a fundamental problem that *cannot* be solved using a single VAL field no matter how you implement it - you're going to throw away information somewhere if a new output demand occurs at about the same time as a new value comes back from the device. You cannot simultaneously hold both a record's last output demand and the value read back from the device, unless this record provides the only possible way to change that output. There is no substitute for having two different places to store the last demand and the readback information.
This means that you cannot have a single button on a display screen which both sets the output value and gets updated whenever the output gets modified by some other means. If you manage to create such a button that appears to work, there will always be some time window where either your button does not show the actual status of the output, or a user's button press will be ignored. Neither of these outcomes is desirable, in both cases the user is likely to complain about flaky software. I can also imagine situations where you could even cause the output to oscillate, although those are slightly harder to cause.
Here at APS the accepted solution to this problem is for our MEDM screens to have buttons or a menu to command the output value, and a separate indicator for the current status coming back from the device. You can use menu or radio buttons for the demand, but you must still have the separate status feedback as well. Eric Norum pointed out that command buttons should use verbs and the status displays adjectives (Enable -> Enabled), and this significantly reduces the confusion between the two.
That people are trying to develop bidirectional I/O support is IMHO partly a reflection on the capabilities of our current record types - the output record types really should have a separate field for the readback value in engineering units, but they generally don't. The ao and mbboDirect records both have an RBV field which may be set by the device support and can be monitored by CA clients, but the record support code doesn't convert the long integer value back into engineering units, and neither has the fields to store the back-converted engineering values anyway.
It would make sense to add a field called say IVAL to most of our current output record types to hold the readback channel's engineering value - this would make it much easier for applications developers than requiring them to create a separate input record for the readback channel.
- Andrew
Dear God, I didn't think orange went with purple until I saw
the sunset you made last night.  That was really cool. - Caro
Re: Bidirectional device support Peregrine McGehee
Re: Record processing knowledge of dbAccess context Peregrine McGehee
Re: Record processing knowledge of dbAccess context Marty Kraimer
Prev: Re: Record processing knowledge of dbAccess context Marty Kraimer
Next: Re: Bidirectional device support Peregrine McGehee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
