1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MVME5110
To: Dirk Zimoch <[email protected]>
Cc: TECHTALK <[email protected]>
Date: Wed, 14 Apr 2004 11:14:33 -0500
Dirk Zimoch wrote:
The delay is *before* anything happens on the network:
-> reboot
[30 seconds delay]
Press any key to stop auto-boot...
 0
auto-booting...
[all the boot parameters printed here]
Attached TCP/IP interface to fei0. [no delay here!]
Attaching network interface lo0... done.
Loading... 1461088
Starting at 0x100000...
[30 seconds delay]
Attached TCP/IP interface to fei unit 0 [no delay here!]
How much RAM do you have on this board, and how much VME space are you mapping for CPU access? It can take vxWorks quite a long time (and RAM) to create all of the MMU's Page Table Entries (PTEs) for the memory and VME areas listed in your sysPhysMemDesc[] table, especially if you're mapping in a large amount of VME A32 space. That PTEs get created twice during the boot sequence at exactly the points you mention having a delay. RAM usage for PTEs is I believe a ratio of 1/128 (i.e. a 128MB mapping needs 1MB for PTEs), but that ratio varies between CPU families.
I use the PPC's BAT registers to map in the A32 space, which is much faster than creating PTEs but it does limit you to only 1GB because there are only 4 DBAT registers with a maximum mapping size of 256MB. Of course if you have more RAM than you need for A32 space then it might make more sense to swap the two and use PTEs for A32 and BATs for RAM, but if you try that be aware there may be complications in doing so.
If you have much more RAM than you need, you could also turn off the vxWorks auto-memory sizing and just don't use it all, which will speed up the PTE creation time.
- Andrew
Dear God, I didn't think orange went with purple until I saw
the sunset you made last night.  That was really cool. - Caro
Re: MVME5110 Dirk Zimoch
RE: MVME5110 Mark Rivers
Prev: Re: MVME5110 Billy R. Adams
Next: Re: MVME5110 Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
