Hello All,
I need gateway applications for multiple IOC
data collection.
I tried compile gateway2.0 under Linux
and solaris, the error message was below:
The makefile using 3.13.x compatible
config directory, not used 3.14.5 configure files.
Used gateway version:
gateway2_0_0_0Beta8 (13 Feb 2004) - needs R3.14.5 base.
[eioc-1:/home/users/kmha/epics/extensions/src/gateway]%
make
make -C O.solarisGnu -f ../Makefile.Host T_A=solarisGnu BUILD_TYPE=Host install make[1]: Entering directory `/home/users/kmha/epics/extensions/src/gateway/O.solarisGnu' g++ -ansi -pedantic -Wtraditional -DSOLARIS=8 -O -Wall -Wmissing-prototypes -Woverlo e-strings -Wconversion -Wstrict-prototypes -Wpointer-arith -Winline -DSTAT_PVS -DRATE_ -DCAS_DIAGNOSTICS -DHANDLE_EXCEPTIONS -DRESERVE_FOPEN_FD -fPIC -D_REENTRANT -DUNIX -D -I../../../include -I../../../include/os/solaris -I/home/users/kmha/epics/base/base-3. aris -I/home/users/kmha/epics/base/base-3.13.9/include -c ../gateway.cc ../gateway.cc: In function `int startEverything(char*)': ../gateway.cc:548: warning: int format, pid_t arg (arg 4) ../gateway.cc: In function `int setEnv(const char*, const char*, char**)': ../gateway.cc:1356: `epicsEnvSet' undeclared (first use this function) ../gateway.cc:1356: (Each undeclared identifier is reported only once for each function it appears in.) ../gateway.cc: In function `void printRecentHistory()': ../gateway.cc:1404: warning: int format, pid_t arg (arg 3) make[1]: *** [gateway.o] Error 1 make[1]: Leaving directory `/home/users/kmha/epics/extensions/src/gateway/O.solarisGnu' make: *** [install.solarisGnu] Error 2 [eioc-1:/home/users/kmha/epics/extensions/src/gateway]% [eioc-1:/home/users/kmha/epics/extensions/src/gateway]% [eioc-1:/home/users/kmha/epics/extensions/src/gateway]% make make -C O.solarisGnu -f ../Makefile.Host T_A=solarisGnu BUILD_TYPE=Host install make[1]: Entering directory `/home/users/kmha/epics/extensions/src/gateway/O.solarisGnu' g++ -ansi -pedantic -Wtraditional -DSOLARIS=8 -O -Wall -Wmissing-prototypes -Woverlo e-strings -Wconversion -Wstrict-prototypes -Wpointer-arith -Winline -DSTAT_PVS -DRATE_ -DCAS_DIAGNOSTICS -DHANDLE_EXCEPTIONS -DRESERVE_FOPEN_FD -fPIC -D_REENTRANT -DUNIX -D -I../../../include -I../../../include/os/solaris -I/home/users/kmha/epics/base/base-3. aris -I/home/users/kmha/epics/base/base-3.13.9/include -c ../gateway.cc ../gateway.cc: In function `int startEverything(char*)': ../gateway.cc:548: warning: int format, pid_t arg (arg 4) ../gateway.cc: In function `int setEnv(const char*, const char*, char**)': ---------------- error Message begin
../gateway.cc:1356: `epicsEnvSet' undeclared (first use this function) ../gateway.cc:1356: (Each undeclared identifier is reported only once for each function it appears in.) ../gateway.cc: In function `void printRecentHistory()': ../gateway.cc:1404: warning: int format, pid_t arg (arg 3) make[1]: *** [gateway.o] Error 1 make[1]: Leaving directory `/home/users/kmha/epics/extensions/src/gateway/O.solarisGnu' make: *** [install.solarisGnu] Error 2 [eioc-1:/home/users/kmha/epics/extensions/src/gateway]% Kiman,
PLS Control and taskforce team
| ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
