1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PREC
To: Dirk Zimoch <[email protected]>
Cc: TECHTALK <[email protected]>
Date: Fri, 11 Jun 2004 07:01:11 -0500
IOC database access converts DBF_FLOAT to DBR_STRING by calling cvtFloatToString.
Similarly DBF_DOUBLE is converted to DBR_STRING by calling cvtDoubleToString.
Both accept precision as an argument.
In 3.14 they are in <base>/src/libCom/cvtFast/cvtFast.c
For moderate size values precision means number of decimal places. See the code for how it handles large numbers or precision > 8.
Early versions of vxWorks had a very slow implementation of %g format conversion. It could only do about 100 conversions per second on a 68020. Thus cvtFast.c was created.
Note that cvtFast has a number of usefull converrsion routines:
cvtFloatToString(float value, char *pstring, unsigned short precision);
cvtDoubleToString(double value, char *pstring, unsigned short precision);
cvtFloatToExpString(float value, char *pstring, unsigned short precision);
cvtDoubleToExpString(double value, char *pstring, unsigned short precision);
cvtFloatToCompactString(float value, char *pstring, unsigned short precision);
cvtDoubleToCompactString(double value, char *pstring, unsigned short precision);
cvtCharToString(signed char value, char *pstring);
cvtUcharToString(unsigned char value, char *pstring);
cvtShortToString(short value, char *pstring);
cvtUshortToString(unsigned short value, char *pstring);
cvtLongToString(epicsInt32 value, char *pstring);
cvtUlongToString(epicsUInt32 value, char *pstring);
cvtLongToHexString(epicsInt32 value, char *pstring);
cvtLongToOctalString(epicsInt32 value, char *pstring);
Dirk Zimoch wrote:
Hi all,
we all know the PREC field of many records. Unforunately, its purpose is not documented very precisely. The Application Developer's Guide says in chapter 3.5.1 (EPICS Overview - Channel Access - Client Services):
"In addition to requesting process variable values, any combination of the following additional information may be requested:
* Precision: Precision with which to display floating point numbers."
In the Record Reference Manual, one can read e.g. in the ai chapter:
"The PREC field determines the floating point precision with which to display VAL."
But what does this exactly mean? I think, the most intuitive sense is to format the value like "%.<PREC>f". At least this is the default behaviour of medm when using a text monitor. But why not like "%.<PREC>g" or "%.<PREC>e"? And why does neither caget nor camonitor honor PREC? And what about negative PREC values?
I suggest the following:
PREC >= 0 means to format the value like printf("%.*f",PREC,VAL);
PREC < 0  means to format the value like printf("%.*e",-PREC,VAL);
All tools including caget and camonitor should honor PREC.
Any comments?
Dirk
PREC Dirk Zimoch
Prev: Re: PREC Dirk Zimoch
Next: Re: PREC Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: PREC Ralph Lange
Next: Re: PREC Eric Norum
