Dirk Zimoch wrote:
Hi all,
we all know the PREC field of many records. Unforunately, its purpose is
not documented very precisely. The Application Developer's Guide says in
chapter 3.5.1 (EPICS Overview - Channel Access - Client Services):
"In addition to requesting process variable values, any combination of
the following additional information may be requested:
* Precision: Precision with which to display floating point numbers."
In the Record Reference Manual, one can read e.g. in the ai chapter:
"The PREC field determines the floating point precision with which to
display VAL."
But what does this exactly mean? I think, the most intuitive sense is to
format the value like "%.<PREC>f". At least this is the default
behaviour of medm when using a text monitor. But why not like
"%.<PREC>g" or "%.<PREC>e"? And why does neither caget nor camonitor
honor PREC? And what about negative PREC values?
I'm not sure that the most intuitive sense is "%.<PREC>f". I interpret the
documentation to mean that PREC should result in "%.<PREC>g".
I suggest the following:
PREC >= 0 means to format the value like printf("%.*f",PREC,VAL);
PREC < 0 means to format the value like printf("%.*e",-PREC,VAL);
I worry that there are a lot of tools out there that might not take well to
negative PREC values.
All tools including caget and camonitor should honor PREC.
Any comments?
I'd argue that PREC should specify the number of significant digits and that
the style (f/e) should be chosen according to the printf rules:
If the precision is missing, 6 digits are given; if the
precision is zero, it is treated as 1. Style e is used if the
exponent from its conversion is less than -4 or greater than or
equal to the precision. Trailing zeros are removed from the
fractional part of the result; a decimal point appears only if it
is followed by at least one digit.
With PREC=2, pi would print as 3.1, pi/100 as 0.031, pi/10000 as 0.00031,
pi/100000 as 3.1e-5, pi*10 as 31 and pi*100 as 3.1e2.
Eric Norum [email protected]
Advanced Photon Source Phone: (630) 252-4793
Argonne National Laboratory
- Re: PREC Dirk Zimoch
- PREC Dirk Zimoch
Re: PREC Ralph Lange
JCA maintainers John Maclean
<2004>
2025
2026
Re: PREC Marty Kraimer
<2004>
2025
2026
