1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: caRepeater working practices
To: EPICS Tech-Talk <[email protected]>
Date: Mon, 28 Jun 2004 15:41:47 -0400
I generally prefer to use a standard init.d-style script to start and kill
caRepeater at boot and shutdown.  We are using Linux, but I believe the
same applies to Solaris, and probably most current Unix systems.
The primary motivation for this is that the executable comes from an NFS
mounted filesystem, and not killing it off gets in the way of unmounting
that filesystem.  This was a real problem with earlier versions of RedHat
Linux, causing the system to never shutdown properly.  Now, the filesystem
will eventually be forced to unmount, but it's cleaner to kill off
caRepeater first.
Brian McAllister                    Controls Programmer/Beam Physicist
[email protected]                        MIT-Bates Linear Accelerator
(617) 253-9537                                           Middleton, MA
caRepeater working practices Simon Rees
Prev: Re: caRepeater working practices Billy R. Adams
Next: RE: caRepeater working practices Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: caRepeater working practices Jeff Hill
Next: XML-RPC library for PHP Noboru Yamamoto
