1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: caRepeater working practices
To: "'Billy R. Adams'" <[email protected]>, "'Simon Rees'" <[email protected]>
Cc: "'EPICS Tech-Talk'" <[email protected]>
Date: Mon, 28 Jun 2004 13:43:50 -0600
> If is running, then stop it, then start it, ensures a new
> copy is running.
Note that if you abruptly stop a ca repeater that ca clients have become
dependent on then these clients will be left without ca repeater
functionality.
Jeff
> -----Original Message-----
> From: Billy R. Adams [mailto:[email protected]]
> Sent: Monday, June 28, 2004 1:34 PM
> To: Simon Rees
> Cc: EPICS Tech-Talk
> Subject: Re: caRepeater working practices
> Simon,
>       I can't answer the why or if should be needed.
>       Here is how I start it, if needed, in my main C-program.
> (C-code) to automatically detect if caRepeater is already running.  If
> is running, then stop it, then start it, ensures a new copy is running.
> If not running, then start it.
>      I have to start caRepeater on a hybrid system where I have EPICS
> 3.14.5 on a Linux PC and EPICS 3.1.2 on the IOCS used in transitioning
> to EPICS 3.14.5.
>         /* Start "caRepeater" for EPICS-3.14.x on Linux
>         06-05-03  07-10-03  [email protected]
>         1. If running, then first kill "caRepeater"
>         2. Start "caRepeater" */
>         int returnCode;
>         printf ("\n");
>         returnCode = system ("date");
>         returnCode = system ("(ps -elf | awk '{print $15,$4}' | grep
> caRepeater) ");
>         if (returnCode == 0) {
>           fprintf (stdout, "Killing old running 'caRepeater'\n");
> caRepeater) |  kill -9 `aw
> k '{print $2}'`");
>         fprintf (stdout, "Starting
> '/usr/local/epics/bin/linux-x86/caRepeater &'\n");
>         returnCode = system ("/usr/local/epics/bin/linux-x86/caRepeater
> caRepeater) ");
> Simon Rees wrote:
> > Dear all
> > Please excuse the naivety of this question but I am
> > just getting to grips with EPICS here at the Isaac Newton
> > Group of Telescopes. I have searched through the EPICS
> > documentation and so far haven't found any definitive
> > pointers.
> > Is it considered standard practice to start a caRepeater daemon
> > at machine boot time for any machine on which you might want to
> > run CA clients ?  (If there are many potential machines this might
> > be a bit of a burden to the system administrators).
> > Alternatively, do most people just allow the first client
> > which runs on the machine after reboot to spawn the caRepeater
> > and for all subsequent clients on the same machine to use it ?
> > Here at ING we are running with R3.13.1; our clients typically
> > run on Solaris 5.9 workstations.
> > Many thanks
> > Simon Rees
> > Isaac Newton Group of Telescopes
> Billy Adams <mailto:[email protected]>
>                 Sverdrup NASA/Langley ROME Group
>   Assigned to:  Research Facilities Branch of
>                 Research Facilities Services Competency
>   Building 1251, Room 126D
>   NASA Langley Research Center
>   Hampton, Va. 23681-2199
>   Phone 1-757-224-7858     Fax   1-757-224-7870
Re: caRepeater working practices Billy R. Adams
Prev: Re: caRepeater working practices Brian McAllister
Next: Re: caRepeater working practices Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: caRepeater working practices Billy R. Adams
Next: Re: caRepeater working practices Brian McAllister
