1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: caRepeater working practices
To: Simon Rees <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Mon, 28 Jun 2004 15:34:10 -0400
Simon,
I can't answer the why or if should be needed.
Here is how I start it, if needed, in my main C-program.
(C-code) to automatically detect if caRepeater is already running. If is running, then stop it, then start it, ensures a new copy is running. If not running, then start it.
I have to start caRepeater on a hybrid system where I have EPICS 3.14.5 on a Linux PC and EPICS 3.1.2 on the IOCS used in transitioning to EPICS 3.14.5.
/* Start "caRepeater" for EPICS-3.14.x on Linux
06-05-03 07-10-03 [email protected]
1. If running, then first kill "caRepeater"
2. Start "caRepeater" */
int returnCode;
printf ("\n");
returnCode = system ("date");
returnCode = system ("(ps -elf | awk '{print $15,$4}' | grep caRepeater) ");
if (returnCode == 0) {
fprintf (stdout, "Killing old running 'caRepeater'\n");
returnCode = system ("(ps -elf | awk '{print $15,$4}' | grep caRepeater) | kill -9 `aw
k '{print $2}'`");
fprintf (stdout, "Starting '/usr/local/epics/bin/linux-x86/caRepeater &'\n");
returnCode = system ("/usr/local/epics/bin/linux-x86/caRepeater &");
Simon Rees wrote:
Dear all
Please excuse the naivety of this question but I am
just getting to grips with EPICS here at the Isaac Newton
Group of Telescopes. I have searched through the EPICS
documentation and so far haven't found any definitive
pointers.
Is it considered standard practice to start a caRepeater daemon
at machine boot time for any machine on which you might want to
run CA clients ?  (If there are many potential machines this might
be a bit of a burden to the system administrators).
Alternatively, do most people just allow the first client
which runs on the machine after reboot to spawn the caRepeater
and for all subsequent clients on the same machine to use it ?
Here at ING we are running with R3.13.1; our clients typically
run on Solaris 5.9 workstations.
Many thanks
Simon Rees
Isaac Newton Group of Telescopes
Billy Adams <mailto:[email protected]>
               Sverdrup NASA/Langley ROME Group
 Assigned to:  Research Facilities Branch of
               Research Facilities Services Competency
 Building 1251, Room 126D
 NASA Langley Research Center
 Hampton, Va. 23681-2199
 Phone 1-757-224-7858     Fax   1-757-224-7870
RE: caRepeater working practices Jeff Hill
virtual circuit disconnect Zheng Lifang
Re: virtual circuit disconnect Ralph Lange
caRepeater working practices Simon Rees
Prev: RE: caRepeater working practices Jeff Hill
Next: Re: caRepeater working practices Brian McAllister
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: caRepeater working practices Maren Purves
Next: RE: caRepeater working practices Jeff Hill
