Hello Kiman,
I'm interested in this as well, so let me know what you find out as we are beginning
to gear up at BESSY for RTEMS. We plan to use the mv5500, mv2100 and mv162 processors.
First, I'll try what Kate suggested and see if I can port Till's mv167 BSP for RTEMS
to the mv162.
One of our goals is to get the CAN software running under EPICS R3.14.6 and RTEMS for
these processors. We have an mv2400 cpu as well, but we don't have plans to build the
RTEMS BSP for this cpu if it is not already available.
- Regards,
Kristi
-----Original Message-----
To: [email protected]
Cc: [email protected]; Straumann, Till
Sent: 7/16/2004 2:09 AM
Subject: RTEMSfor MVME5500
Hello Kate,
Anyone have to tried compile RTEMS for MVME5500?
Our Control staffs who Mr OH is recently trying to compile RTEM for
MVME5500.
But he reported to me some compile error messages
Used : RTEMS-4.6.0pre1
Gcc3.2.1
He fallowed form your README files;
http://www.nsls.bnl.gov/organization/UserScience/Detectors/Software/READ
ME.t
xt
To build cexp :
0) cd cexp-1.4.beta
1) mkdir build_linux_ppc-rtems
2) cd build_linux_ppc-rtems
3)
....../configure --prefix=/opt/rtems/ppc-rtems --host=ppc-rtems
--with-multisubd
ir=m750 --disable-nls
To build xsyms :
0) cd cexp-1.4.beta
1) mkdir build-xsyms
2) cd build-xsyms
3) ../configure --target=ppc-rtems
---- Passed compile successfully -------
But the compile error is occurs this step;
To build rtems5500-cexp.bin and rtems5500-cexp.sym :
0) cd RTEMS5500-GeSys_2.1.beta
2) make
ldep/ldep.c:659:2: warning: #warning TODO weak symbols
Warning: Symbol without object file??
-> substituting symbol file name, using 'startfiles.o'...
(o-optimize/startfiles.nm/line 1)
Warning: type mismatch between multiply defined symbols
__deregister_frame_info: known as T, is now w
__register_frame_info: known as T, is now w
environ: known as G, is now B
Warning: Object
'/work/rtems/rtems-ppc/lib/gcc-lib/ppc-rtems/3.2.1/../../../../ppc-rtems
/lib
/libbfd.a[archive.o]' couldn't be removed; probably it's needed by the
application
Warning: Object
/lib
/libbfd.a[archures.o]' couldn't be removed; probably it's needed by the
application
Warning: Object
/lib
/libbfd.a[bfd.o]'
Warning: Object
/lib
/libiberty.a[xexit.o]' couldn't be removed; probably it's needed by the
application
Warning: Object
/lib
/libiberty.a[xmalloc.o]' couldn't be removed; probably it's needed by
the
application
Warning: Object
/lib
/libiberty.a[xstrerror.o]' couldn't be removed; probably it's needed by
the
application
Warning: Object 'librtemscpu.a[dummy.o]' couldn't be removed; probably
it's
needed by the application
Warning: Object
/lib
the
application
it's
Object
/lib
/librtemsbsp.a[ftpd.o]' not found!
--- end of error message ---
When are you going to release the BSP source code for MVME5500?
>2) Please copy the rtems5500-cexp.bin, rtems5500-cexp.sym and st.sys
Please could you send to me 3 of binary files for booting from MVME5500.
Kiman Ha,
PLS Control and taskforce team.
RTEMSfor MVME5500 Kiman Ha
Re: Re: GreenSpring TIP810 CANbus system hkm
<2004>
2025
2026
Re: RTEMSfor MVME5500 Kate Feng
RE: RTEMSfor MVME5500 Elder Matias
<2004>
2025
2026
