Hello Kate,
Anyone have to tried compile RTEMS for MVME5500?
Our Control staffs who Mr OH is recently trying to compile RTEM for
MVME5500.
But he reported to me some compile error messages
Used : RTEMS-4.6.0pre1
Gcc3.2.1
He fallowed form your README files;
http://www.nsls.bnl.gov/organization/UserScience/Detectors/Software/README.t
xt
To build cexp :
0) cd cexp-1.4.beta
1) mkdir build_linux_ppc-rtems
2) cd build_linux_ppc-rtems
3)
..../configure --prefix=/opt/rtems/ppc-rtems --host=ppc-rtems --with-multisubd
ir=m750 --disable-nls
To build xsyms :
0) cd cexp-1.4.beta
1) mkdir build-xsyms
2) cd build-xsyms
3) ../configure --target=ppc-rtems
---- Passed compile successfully -------
But the compile error is occurs this step;
To build rtems5500-cexp.bin and rtems5500-cexp.sym :
0) cd RTEMS5500-GeSys_2.1.beta
2) make
ldep/ldep.c:659:2: warning: #warning TODO weak symbols
Warning: Symbol without object file??
-> substituting symbol file name, using 'startfiles.o'...
(o-optimize/startfiles.nm/line 1)
Warning: type mismatch between multiply defined symbols
__deregister_frame_info: known as T, is now w
__register_frame_info: known as T, is now w
environ: known as G, is now B
Warning: Object
'/work/rtems/rtems-ppc/lib/gcc-lib/ppc-rtems/3.2.1/../../../../ppc-rtems/lib
/libbfd.a[archive.o]' couldn't be removed; probably it's needed by the
application
Warning: Object
/libbfd.a[archures.o]' couldn't be removed; probably it's needed by the
application
Warning: Object
/libbfd.a[bfd.o]'
Warning: Object
/libiberty.a[xexit.o]' couldn't be removed; probably it's needed by the
application
Warning: Object
/libiberty.a[xmalloc.o]' couldn't be removed; probably it's needed by the
application
Warning: Object
/libiberty.a[xstrerror.o]' couldn't be removed; probably it's needed by the
application
Warning: Object 'librtemscpu.a[dummy.o]' couldn't be removed; probably it's
needed by the application
Warning: Object
application
Object
/librtemsbsp.a[ftpd.o]' not found!
--- end of error message ---
When are you going to release the BSP source code for MVME5500?
>2) Please copy the rtems5500-cexp.bin, rtems5500-cexp.sym and st.sys
Please could you send to me 3 of binary files for booting from MVME5500.
Kiman Ha,
PLS Control and taskforce team.
- Re: RTEMSfor MVME5500 Kate Feng
Re: GreenSpring TIP810 CANbus system Ralph Lange
RE: RTEMSfor MVME5500 Luchini, Kristi
<2004>
2025
2026
RE: GreenSpring TIP810 CANbus system Allison, Stephanie
<2004>
2025
2026
