1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Canot write PVs when restore snapshot using burtwb
To: <[email protected]>
Date: Fri, 19 Nov 2004 11:42:14 +0800
hi
In our application, we try  to use BURT to backup and restore IOC PVs' setting.  Everything is OK when we backup the PVs with burtrb. But when we use burtwb to restore the values, it cannot write the PV at all. We checked the  burtwb logfile, it indicates all values successfully written. When we use ca_test to access these PVs, it works well.
We didnot use BURT before, I will appreciate it very much if someone can give me some instructions or proposals?
Thanks for your help.
HU Yong
SSRF,CAS
request file:
# Power Supply Database PV backup reguest file
# DING Jianguo, SSRF
# firstly created: 2004/11/8
ding:aoExample
Snapshot file:
--- Start BURT header
Time:     Mon Nov 15 21:32:11 2004
Login ID: linac ()
Eff  UID: 501
Group ID: 501
Keywords:
Comments:
Type:     Absolute
Directory /control/epicsApp/dingtest/snap
Req File: req
--- End BURT header
ding:aoExample 1 1.300000000000000e+01
Restort Log file:
**** WRITE BURT LOGFILE
--- Start processing snapshot files
file >out1<
pv >ding:aoExample< nelem 1
--- End processing snapshot files
--- Start reading dependency files
--- End reading dependency files
processing all dependency files ... done
--- Start searches
ding:aoExample ... ca_search_and_connect() ... OK
--- End searches
Waiting for 1 outstanding search(es) ...
found all OK
--- Start writes
ding:aoExample ... ca_array_put() nelem 1 ... OK
flushing with ca_flush_io() ... OK
--- End writes
did not find any read only notify values ... NO OUTPUT FILE CREATED
**** END BURT LOGFILE
Prev: Re: Problem building epics base-3.14.6 with recent gcc on linux Ernest L. Williams Jr.
Next: Re: Problem building epics base-3.14.6 with recent gcc on linux Chip Piller
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problem building epics base-3.14.6 with recent gcc on linux Chip Piller
Next: Epics assert fail Michael Abbott
