1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: if-then-else in iocsh
To: Emmanuel Mayssat <[email protected]>
Cc: [email protected]
Date: Fri, 28 Jan 2005 10:43:30 -1000
Andrew Johnson wrote:
Emmanuel Mayssat wrote:
I use "dbLoad" files such as this one:
<snip>
Now, I would like to include in my dbl files a command that says:
If this variable is not set, then set it to this value.
This technique appears to be somewhat fragile (meaning you must be careful if you decide to use it). It's probably fine if you have a small number of .dbl files and can keep track of all the variables that each one needs, but what happens if you should re-use a variable name (with different default values) in two different dbl files? The first dbl file would set the value it wants as the default, but the second file would always see the earlier file's default setting (because the variable was never unset), even if the user really wanted to use the second dbl file's default. Swapping the order in which you execute the two dbl files would change what is loaded into the database!
I would suggest that you require that the parent script must set *all* parameters that a dbl file relies on itself, or load a single default settings file early on like Eric suggested.
If you don't intend to change it once the iocInit is done, why not get it in at the "make" stage, and substitute the variables there, allowing you to check in the built script what you're actually going to end up with in the ioc?
Maren
if-then-else in iocsh Emmanuel Mayssat
Re: if-then-else in iocsh Andrew Johnson
Re: if-then-else in iocsh Maren Purves
Re: if-then-else in iocsh Emmanuel Mayssat
Prev: Re: if-then-else in iocsh Andrew Johnson
Next: Re: if-then-else in iocsh Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
