1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VxWorks5.5 on MVME230x doesn't reestablish broken N/W link
To: <[email protected]>
Cc: "EPICS tech-talk" <[email protected]>
Date: Thu, 29 Sep 2005 09:38:17 +0200
It's TSR# 453418.
I don't send copies of the files around. They are property of WRS. It is [email protected] who sent them to SLS. Unfortunately, he didn't add a revision number to the files when he changed them recently. So, the latest revision entries in the files are
dec21x40End.h 22sep03,mni added BOOL restarting member to DEC21X40_DRV_CTRL structure
dec21x40End.c 22sep03,mni added fix for SPR# 84658
Please check with Mr Niedermair if he did essential changes since.
Kind regards,
Andy
Andreas Isenegger
SLS Controls
Paul Scherrer Institute, WSLA/207
CH-5232 Villigen PSI, Switzerland
Tel/Fax: ++41 (56) 310 5125/4413
----- Original Message ----- From: "Ernest L. Williams Jr." <[email protected]>
To: "Andreas Isenegger" <[email protected]>
Sent: Thursday, September 29, 2005 12:55 AM
On Wed, 2005-09-28 at 17:12 +0200, Andreas Isenegger wrote:
Hello All,
Since I posted 2 e-mails in July 2005 seeking for help, I thought it would
be worth informing you that the problem could be solved.
There are indeed some bugs in Wind River's N/W driver (dec21x40End.h/c) that
cause the misbehavior of the IOC. I got new revisions of these files from
Martin Niedermair, WRS Austria, which solve the issue. Strangely enough, a
different support engineer of WRS sent me another revision of the same
files, which doesn't fix the bug. About 2 years back, they were branched...
. The latest official patch from WRS contains again different revisions of
the files.
Thus, if you are experiencing troubles with IOC's disconnecting for 'no
reasons', or reset ports of N/W switches to regain links to IOC's, build a
new VxWorks image with the latest revision of these files.
Can you send us a copy of the files or give us a rev. number to compare
against?
I think we are fine but I want to double-check.
Our MVME2101s also use the "dec21x40End.h/c"
PS: Did WRS give you a TSR or SPR that we could look up on our end?
Thanks, Ernest L. Williams Jr. SNS Control Systems Group ORNL
Kind regards, Andreas Isenegger
Andreas Isenegger
SLS Controls
VxWorks5.5 on MVME230x doesn't reestablish broken N/W link Andreas Isenegger
Re: VxWorks5.5 on MVME230x doesn't reestablish broken N/W link Ernest L. Williams Jr.
Prev: Re: VxWorks5.5 on MVME230x doesn't reestablish broken N/W link Ernest L. Williams Jr.
Next: RE: VxWorks TIMEZONE hack, anyone? Rees, NP (Nick)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: TSconfigure documentation Denison, PN (Peter)
