1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Channel access problem on cygwin IOC
To: "Mark Rivers" <[email protected]>, "Jeff Hill" <[email protected]>, <[email protected]>
Date: Fri, 30 Sep 2005 16:07:53 -0500
Jeff,
I just learned a little more about the caRepeater problem.  When I did the tests in my previous message I had not run any Windows CA clients that would have started a Windows caRepeater task.  When I started the IOC it started a caRepeater task that appears with "ps -a" in cygwin, but did not appear in the Windows Task Manager.  I got the error saying that CA could not find the caRepeater.  The copy of caRepeater that was started under cygwin had the unfortunate property that it had a file open that my IOC application had opened, and that file could not be deleted until that copy of caRepeater was killed.
I then started medm on the Windows machine, which created a caRepeater task that shows up in the Windows Task Manager.  That time starting the IOC did not start a caRepeater task, since it must have found the one that was running under Windows.  However, I still got the following error at the IOC:
epics> CA client library is unable to contact CA repeater a
Silence this message by starting a CA repeater daemon
or by calling ca_pend_event() and or ca_poll() more often.
But at least this copy of caRepeater does not have the file locked that needs to be deleted!
Do you understand what is going on?
Sent: Fri 9/30/2005 3:33 PM
To: Jeff Hill; [email protected]
Jeff,
The think the problem might have been caused by EPICS launching a second copy of my IOC instead of caRepeater one time.  So there were two copies of the IOC application running, causing the IP problem?
There is something else I don't understand about caRepeater behavior on this IOC.
Here is a list of cygwin processes before I start my IOC.
$ ps -a
      PID    PPID    PGID     WINPID  TTY  UID    STIME COMMAND
     1364       1    1364       1364    ?   18 20:29:52 /usr/bin/cygrunsrv
     1660    1364    1660       1672    ?   18 20:29:57 /usr/sbin/sshd
I     460       1     460        460    0 11092 20:31:24 /usr/bin/bash
     2280       1    2280       2280    1 11092 14:02:41 /usr/bin/bash
     3808    2280    3808       2740    1 11092 14:03:38 /usr/bin/ps
Now I start the IOC. Note that the path to caRepeater in EPICS base is in my cygwin PATH.  Now list the processes again.
$ ps -a
I    2112     460    2112       3008    0 11092 14:03:49 /cygdrive/j/epics/devel/dxp/2-4beta/bin/cygwin-x86/xmapApp
      736    2112    2112       3284    0 11092 14:04:49 /cygdrive/h/epics/base/bin/cygwin-x86/caRepeater
     3932    2280    3932       3456    1 11092 15:14:12 /usr/bin/ps
xmapApp is the IOC process.  Note that starting the IOC has started the caRepeater, as it should have.
However, I get the following message from iocsh on the IOC after iocInit is complete.
CA client library is unable to contact CA repeater after 50
This does not seem right.  Why am I getting that error message even though caRepeater was in fact successfully started?
RE: Channel access problem on cygwin IOC Jeff Hill
Prev: Re: Possible improvements to simulation mode [patch] Ned Arnold
Next: RE: Channel access problem on cygwin IOC Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Channel access problem on cygwin IOC Mark Rivers
