Mark,
> The copy of caRepeater that was started under
> cygwin had the unfortunate property that it had a file open that my IOC
> application had opened, and that file could not be deleted until that copy
> of caRepeater was killed.
This is a fun "feature" of POSIX. On POSIX subsystems we used to close *all*
file numbers (other than stdin/out/err) before launching the caRepeater
using exec in the process created with fork. We received a complaint that
this was too intrusive (I think that there was some issue on HPUX).
Therefore, base now open all sockets specifying the FD_CLOEXEC option and
lets the OS take care of this matter.
You will also need to set the FD_CLOEXEC option when opening a file on POSIX
systems in any process that uses fork and exec to start a detached process.
Attached are the codes that start the caRepeater depending on if the
repeater is started with cygwin-x86 (POSIX) or with win32-x86.
> I then started medm on the Windows machine, which created a caRepeater
> task that shows up in the Windows Task Manager. That time starting the
> IOC did not start a caRepeater task, since it must have found the one that
> was running under Windows. However, I still got the following error at
> the IOC:
> epics> CA client library is unable to contact CA repeater a
> Do you understand what is going on?
Nope. My guess is that the cygwin socket subsystem somehow isn't forwarding
UDP to the win32 socket subsystem.
And I was whining about having to support both cygwin-x86 and win32-x86 when
I dint know that we could look forward to the "cygwin-x86-blend-win32-x86"
system :-)
Jeff
On POSIX:
epicsShareFunc osiSpawnDetachedProcessReturn epicsShareAPI
(const char *pProcessName, const char *pBaseExecutableName)
int status;
* create a duplicate process
status = fork ();
if (status < 0) {
return osiSpawnDetachedProcessFail;
* return to the caller
* if its in the initiating process
if (status) {
return osiSpawnDetachedProcessSuccess;
* since all epics sockets are created with the FD_CLOEXEC
* option then we no-longer need to blindly close all open
* files here.
* overlay the specified executable
status = execlp (pBaseExecutableName, pBaseExecutableName, NULL);
if ( status < 0 ) {
fprintf ( stderr, "**** The executable \"%s\" couldn't be
located\n", pBaseExecutableName );
fprintf ( stderr, "**** because of errno = \"%s\".\n", strerror
(errno) );
fprintf ( stderr, "**** You may need to modify your PATH environment
variable.\n" );
fprintf ( stderr, "**** Unable to start \"%s\" process.\n",
pProcessName);
exit ( -1 );
On WIN32:
( const char *pProcessName, const char *pBaseExecutableName )
BOOL status;
STARTUPINFO startupInfo;
PROCESS_INFORMATION processInfo;
GetStartupInfo ( &startupInfo );
startupInfo.lpReserved = NULL;
startupInfo.lpTitle = (char *) pProcessName;
startupInfo.dwFlags = STARTF_USESHOWWINDOW;
startupInfo.wShowWindow = SW_SHOWMINNOACTIVE;
status = CreateProcess (
NULL, // pointer to name of executable module
(not required if command line is specified)
(char *) pBaseExecutableName, // pointer to
command line string
NULL, // pointer to process security attributes
NULL, // pointer to thread security attributes
FALSE, // handle inheritance flag
CREATE_NEW_PROCESS_GROUP | DETACHED_PROCESS, //
creation flags
NULL, // pointer to new environment block
(defaults to caller's environement)
NULL, // pointer to current directory name
(defaults to caller's current directory)
&startupInfo, // pointer to STARTUPINFO
&processInfo // pointer to PROCESS_INFORMATION
if ( status == 0 ) {
DWORD W32status;
LPVOID errStrMsgBuf;
LPVOID complteMsgBuf;
W32status = FormatMessage (
FORMAT_MESSAGE_ALLOCATE_BUFFER |
FORMAT_MESSAGE_FROM_SYSTEM,
NULL,
GetLastError (),
MAKELANGID (LANG_NEUTRAL, SUBLANG_DEFAULT), //
Default language
(LPTSTR) &errStrMsgBuf,
0,
NULL
if ( W32status ) {
char *pFmtArgs[6];
pFmtArgs[0] = "Failed to start executable -";
pFmtArgs[1] = (char *) pBaseExecutableName;
pFmtArgs[2] = errStrMsgBuf;
pFmtArgs[3] = "Changes may be required in your \"path\"
environment variable.";
pFmtArgs[4] = "PATH = ";
pFmtArgs[5] = getenv ("path");
if ( pFmtArgs[5] == NULL ) {
pFmtArgs[5] = "<empty string>";
W32status = FormatMessage(
FORMAT_MESSAGE_FROM_STRING |
FORMAT_MESSAGE_ARGUMENT_ARRAY | 80,
"%1 \"%2\". %3 %4 %5 \"%6\"",
0,
// Default language
(LPTSTR) &complteMsgBuf,
0,
pFmtArgs
if (W32status) {
// Display the string.
MessageBox (NULL, complteMsgBuf,
"Configuration Problem",
MB_OK | MB_ICONINFORMATION);
LocalFree (complteMsgBuf);
else {
MessageBox (NULL, errStrMsgBuf, "Failed to
start executable",
// Free the buffer.
LocalFree (errStrMsgBuf);
else {
errlogPrintf ("!!WARNING!!\n");
errlogPrintf ("Unable to locate executable
\"%s\".\n", pBaseExecutableName);
errlogPrintf ("You may need to modify your
environment.\n");
// use of spawn here causes problems when the ca repeater
// inherits open files (and sockets) from the spawning
// process
//status = _spawnlp (_P_DETACH, pBaseExecutableName,
//if (status<0) {
// errlogPrintf ("!!WARNING!!\n");
// errlogPrintf ("Unable to locate the EPICS executable
\"%s\".\n",
// pBaseExecutableName);
// errlogPrintf ("You may need to modify your environment.\n");
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: Friday, September 30, 2005 3:08 PM
> To: Mark Rivers; Jeff Hill; [email protected]
> Subject: RE: Channel access problem on cygwin IOC
> Jeff,
> I just learned a little more about the caRepeater problem. When I did the
> tests in my previous message I had not run any Windows CA clients that
> would have started a Windows caRepeater task. When I started the IOC it
> started a caRepeater task that appears with "ps -a" in cygwin, but did not
> appear in the Windows Task Manager. I got the error saying that CA could
> not find the caRepeater. The copy of caRepeater that was started under
> the IOC:
> Silence this message by starting a CA repeater daemon
> or by calling ca_pend_event() and or ca_poll() more often.
> But at least this copy of caRepeater does not have the file locked that
> needs to be deleted!
> Thanks,
> Mark
> ________________________________
> From: Mark Rivers
> Sent: Fri 9/30/2005 3:33 PM
> To: Jeff Hill; [email protected]
> Jeff,
> The think the problem might have been caused by EPICS launching a second
> copy of my IOC instead of caRepeater one time. So there were two copies
> of the IOC application running, causing the IP problem?
> There is something else I don't understand about caRepeater behavior on
> this IOC.
> Here is a list of cygwin processes before I start my IOC.
> $ ps -a
> PID PPID PGID WINPID TTY UID STIME COMMAND
> 1364 1 1364 1364 ? 18 20:29:52 /usr/bin/cygrunsrv
> 1660 1364 1660 1672 ? 18 20:29:57 /usr/sbin/sshd
> I 460 1 460 460 0 11092 20:31:24 /usr/bin/bash
> 2280 1 2280 2280 1 11092 14:02:41 /usr/bin/bash
> 3808 2280 3808 2740 1 11092 14:03:38 /usr/bin/ps
> Now I start the IOC. Note that the path to caRepeater in EPICS base is in
> my cygwin PATH. Now list the processes again.
> $ ps -a
> I 2112 460 2112 3008 0 11092 14:03:49
> /cygdrive/j/epics/devel/dxp/2-4beta/bin/cygwin-x86/xmapApp
> 736 2112 2112 3284 0 11092 14:04:49
> /cygdrive/h/epics/base/bin/cygwin-x86/caRepeater
> 3932 2280 3932 3456 1 11092 15:14:12 /usr/bin/ps
> xmapApp is the IOC process. Note that starting the IOC has started the
> caRepeater, as it should have.
> However, I get the following message from iocsh on the IOC after iocInit
> is complete.
> CA client library is unable to contact CA repeater after 50
> This does not seem right. Why am I getting that error message even though
> caRepeater was in fact successfully started?
> Thanks,
> Mark
- RE: Channel access problem on cygwin IOC Mark Rivers
Gateway 2.0.0.0 Released Kenneth Evans, Jr.
<2005>
2025
2026
EPICS meeting: timetable and organization Matthias Clausen
<2005>
2025
2026
