Hi John,
To me it does actually look like there's one "make" missing in the extensions/configure
subdirectory.
Remember that running "make" inside the configure directory creates
Makefile snippets that get included during all make runs under this
TOP. These Makefile snippets contain (among other things) search path
definitions for includes and libraries.
The pearl script that creates the library path definitions will only
add directories that actually contain libraries - this is to avoid
adding countless empty directories to the search paths.
If you created librecIoc.a in base after you ran make in extensions/configure,
your Makefile snippets might not contain the correct library location
within base. As a result, make will try to find librecIoc.a
only locally, i.e. under this TOP directory. It's not there,
and cannot be created locally, so make complains correctly about
*** No rule to make target `../../../../lib/linux-x86//librecIoc.a
General rule of thumb: If a make run yields errors that look
like it's trying to find a library locally which should be found
elsewhere ...
- Make sure the path to the external module (in which the library
is located) is set correctly in TOP/configure/RELEASE.
- Make sure the library does exist in that module at the generic
location (e.g. MODULE/lib/ARCHITECTURE)
- Do a "make clean", then "make" (or shorter: "make clean all")
inside TOP/configure.
If it still doesn't work, well ... shit happens.
Good luck!
Ralph
Kay-Uwe Kasemir wrote:
Hi:
Well, I cannot duplicate your exact setup right now,
- Re: Channel Archiver/ Extension Build Question John Dobbins
- Channel Archiver/ Extension Build Question John Dobbins
- Re: Channel Archiver/ Extension Build Question Kay-Uwe Kasemir
RE: help guobao shen
<2005>
2025
2026
<2005>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
