1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ASYN/devGPIB/GPIBCVTIO problem
To: Tim Mooney <[email protected]>
Cc: [email protected]
Date: Sun, 05 Feb 2006 11:09:13 -0500
Tim,
Thanks for the clarification. The Record Reference Manual (Chapter 1) reads:
"For input links such as INP or DOL (desired output location), if they specify PP, they will cause the record whose address they contain to process when the records containing them are processed ... This means that the value will be retrieved from the specified record only after the record has processed its data."
Which I had understood to mean that the input link would in fact fetch a fresh value.
John
Tim Mooney wrote:
John, regarding...
John Dobbins wrote:
Dear All,
I am confused about what is happening with an Analog In record connected to an ASYN device. In particular this is a devGPIB device with a command of type GPIBCVTIO.
I have created the custom convert routine for this devGPIB GPIBCVTIO command and it appears to work, i.e. I have connected it to an Analog In record and if from the EPICS command line I force the record to process (dbpf aiRecord.PROC 1) and then examine the record's value (dbpr aiRecord) it has correctly retrieved the value from hardware.
However, I next did the following:
I added a dfanout record and an Analog Out record. All three records are passive. I set the DOL of the dfanout record to be the "aiRecord.VAL PP" and OUTA of the dfanout record to be the "aoRecord.VAL PP".
aiRecord -> dfanoutRecord -> aoRecord
I see this behavior when I make dfanoutRecord process:
1) aiRecord processes
3) ao record processes writing the stale value, i.e. the value the aiRecord had before it processed
Note, from ASYN diagnostic output I see #1 happen and then #3 happen.
I infer that in between these the following happened
2) dfanoutRecord retrieved stale data from aiRecord and passed it to aoRecord
So the question is why is the dfanout record retrieving the stale value? It seems it must be that the value is retrieved before the aiRecord is actually done processing.
The last lines of my convert routine are:
       precord->val = floatData;
       precord->udf = 0;
      return 0;
After which the code in devGPIB is responsible for setting PACT = 0.
Have I gone wrong somewhere? Any advice appreciated.
info: EPICS 3.14.7, ASYN 4.2.1, Linux IOC
That's the way it's supposed to work.  The only thing that waits for
asynchronous processing is the forward link of the record whose device
support is asynchronous.  This is not peculiar to ASYN; it's a general
feature of asynchronous processing.  A PP input link starts processing
that will eventually return the new value, but just takes whatever value
is there.  Otherwise it would hold up all the other records being processed
by the same task.
John Dobbins wrote:
 > A follow up note:
 > I changed dfanoutRecord DOL to be "aiRecord.VAL NPP" and then used a seq
 > record to first process aiRecord and then after a delay process
 > dfanoutRecord.
 > This fixes the bad behavior which is consistent with the theory that
 > dfanout was grabbing aiRecord.VAL too soon.
 > Also note that if I replace dfanout with an ao, DTYP = "Soft Channel" I
 > see the same behavior, so this problem is not specific to dfanout.
You might also have the forward link of the AI record process the dFanout
record.  Then you would not have to guess how long a delay to use.
Re: ASYN/devGPIB/GPIBCVTIO problem Andrew Johnson
ASYN/devGPIB/GPIBCVTIO problem John Dobbins
Re: ASYN/devGPIB/GPIBCVTIO problem Tim Mooney
Prev: Re: ASYN/devGPIB/GPIBCVTIO problem Tim Mooney
Next: RE: ASYN/devGPIB/GPIBCVTIO problem Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: ASYN/devGPIB/GPIBCVTIO problem Andrew Johnson
