1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ASYN/devGPIB/GPIBCVTIO problem
To: John Dobbins <[email protected]>
Cc: Tim Mooney <[email protected]>, [email protected]
Date: Mon, 06 Feb 2006 09:45:30 -0600
John Dobbins wrote:
Thanks for the clarification. The Record Reference Manual (Chapter 1) reads:
"For input links such as INP or DOL (desired output location), if they specify PP, they will cause the record whose address they contain to process when the records containing them are processed ... This means that the value will be retrieved from the specified record only after the record has processed its data."
Which I had understood to mean that the input link would in fact fetch a fresh value.
Your understanding of what was written was correct, unfortunately the wording is actually wrong. I have modified the Wiki version of this paragraph to mention the async behavior, although it really needs someone knowledgable to go through this chapter to find and fix up this kind of problem with the wording. Any volunteers out there?
- Andrew
* * Matt Santos / / For a Brighter America * *
ASYN/devGPIB/GPIBCVTIO problem John Dobbins
Re: ASYN/devGPIB/GPIBCVTIO problem Tim Mooney
Re: ASYN/devGPIB/GPIBCVTIO problem John Dobbins
Prev: RE: ASYN/devGPIB/GPIBCVTIO problem Mark Rivers
Next: Re: ASYN/devGPIB/GPIBCVTIO problem Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: ASYN/devGPIB/GPIBCVTIO problem John Dobbins
