1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ASYN/devGPIB/GPIBCVTIO problem
To: [email protected]
Date: Mon, 6 Feb 2006 17:33:48 +0100
On Sunday 05 February 2006 15:15, Tim Mooney wrote:
> John Dobbins wrote:
> >       aiRecord -> dfanoutRecord -> aoRecord
> > I see this behavior when I make dfanoutRecord process:
> > 1) aiRecord processes
> > 3) ao record processes writing the stale value, i.e. the value the
> > aiRecord had before it processed
> That's the way it's supposed to work.
I beg to differ. It may be well-documented (and historically
understandable), but it still is an annoying and frustrating
mis-feature, and definitely not how any sane person would expect it to
work.
> it's a general
> feature of asynchronous processing.  A PP input link starts
> processing that will eventually return the new value, but just takes
> whatever value is there.  Otherwise it would hold up all the other
> records being processed by the same task.
Not if asynchonicity could be inherited via input or output links. Which
would mean (1) every record support must support asynchronous
processing and (2) we can pass a callback to dbPutLink resp. dbGetLink.
That's it, mostly.
V4 was supposed to fix this limitation (and many others). Maybe this one
would be a candidate for inclusion into some V3.16? I'll hapily
volunteer to hack the IOC core to support this...
Ben
RE: ASYN/devGPIB/GPIBCVTIO problem Redman, Russell
ASYN/devGPIB/GPIBCVTIO problem John Dobbins
Re: ASYN/devGPIB/GPIBCVTIO problem Tim Mooney
Prev: Re: ASYN/devGPIB/GPIBCVTIO problem Andrew Johnson
Next: Two Hytec VSD 2992 CAMAC serial highway driver in one VME crate Evgeniy Tikhomolov
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: ASYN/devGPIB/GPIBCVTIO problem Redman, Russell
