We have. It does the same thing.
As far as I can tell, it actually dies when it tries to build_all, and
since build_all appears to be the first step for almost all the real
build targets, they all fail (it appears it is happy to create tar and
zip archives, as well as clean_all, but that's not really building
Archive Viewer).
Now, my collegue, Yury Gorbunov has been trying the same thing on a
different computer. On that machine, he got different error. It
looks like this:
ant configure_jsp
Buildfile: build.xml
-create_build_dir:
build_all:
[javac] Compiling 842 source files to
/home/sysuser/epics.3.14.7/archive_viewer-1-0-4/build
[javac] /home/sysuser/epics.3.14.7/archive_viewer-1-0-4/src/org/jfree/chart/urls/StandardCategoryURLGenerator.java:
In class `org.jfree.chart.urls.StandardCategoryURLGenerator':
In method `org.jfree.chart.urls.StandardCategoryURLGenerator.generateURL(org.jfree.data.category.CategoryDataset,int,int)':
[javac] /home/sysuser/epics.3.14.7/archive_viewer-1-0-4/src/org/jfree/chart/urls/StandardCategoryURLGenerator.java:139:
warning: The method `java.net.URLEncoder.encode(java.lang.String)'
inclass `java.net.URLEncoder' has been deprecated.
[javac] + URLEncoder.encode(seriesKey.toString());
[javac] ^
[javac] /home/sysuser/epics.3.14.7/archive_viewer-1-0-4/src/org/jfree/chart/urls/StandardCategoryURLGenerator.java:147:
[javac] + URLEncoder.encode(categoryKey.toString());
[javac] ^
[javac] /home/sysuser/epics.3.14.7/archive_viewer-1-0-4/src/epics/archiveviewer/plotplugins/jfreechart/JFreeChartPlotImageGenerator.java:
In class `epics.archiveviewer.plotplugins.jfreechart.JFreeChartPlotImageGenerator':
In method `access$93(java.awt.Image)':
[javac] /home/sysuser/epics.3.14.7/archive_viewer-1-0-4/src/epics/archiveviewer/plotplugins/jfreechart/JFreeChartPlotImageGenerator.java:100:
error: Exception `java.lang.Exception' must be caught, or it must be
declared in the `throws' clause of `access$93'.
[javac] }
[javac] ^
In method `access$92(java.awt.Image)':
declared in the `throws' clause of `access$92'.
[javac] }
[javac] ^
[javac] 2 errors, 2 warnings
BUILD FAILED
file:/home/sysuser/epics.3.14.7/archive_viewer-1-0-4/build.xml:21:
Compile failed; see the compiler error output for details.
Total time: 52 seconds
I believe this was also done on SL 3.0.5. However, that machine had
Java 1.4 instead of 1.5 installed. I am willing to try with Java 1.4
on the machine I have been working on this afternoon.
On 2/14/06, Sergei Chevtsov <[email protected]> wrote:
> Hi!
> Can you try the simpler ant target for ArchiveViewer, namely:
> ant build_all
> please?
> Thank you,
> Sergei
> Jiro Fujita wrote:
> >I also tried compiling simple Java program with ant, and so far, I
> >have been successful (I followed the first part of "Apache ant
> >Demystified"
> >http://www.sitepoint.com/print/apache-ant-demystified).
- Re: building EPICS ArchiveViewer Jiro Fujita
- building EPICS ArchiveViewer Jiro Fujita
- Re: building EPICS ArchiveViewer Sergei Chevtsov
Re: labCA crashes with bad PV Dennis Nicklaus
FLNK loop Emmanuel Mayssat
<2006>
2025
2026
<2006>
2025
2026
