1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: drvAscii decode string
To: "Ian A Smith" <[email protected]>, <[email protected]>
Date: Tue, 25 Apr 2006 08:41:47 -0500
Ian,
I have several instances similar to this, where other text makes getting the number I want almost impossible.  You might try <%5k%e;%*f;%*f;%*f;%*f>, if this doesn't work (most often because there is a space in the text that can't be matched), then read the info into a stringin record and forward link to a soft ai record that gets it's VAL from the stringin record.
Rodney Porter
Sent: Tue 4/25/2006 5:51 AM
To: [email protected]
Subject: drvAscii decode string
I'm trying to read the following into an ascii analogin record:
"=V913 1.13e-04;59;11;0;0"
  and to extract the 1.13e-04 or whatever.  Using <%5k%f> just times out
and so does <=V913%f>.  Using %e makes no difference.  If I read the
value into a stringin record, there is no problem apart from the fact
that it's a string.
Any suggestions?
TIA
Ian A Smith               Telephone: +44 (0) 131 668 8255
Royal Observatory         Fax:       +44 (0) 131 668 8314
Blackford Hill            Web:       http://www.roe.ac.uk/
Edinburgh
EH9 3HJ
UK
Re: drvAscii decode string Matt Rippa
Prev: drvAscii decode string Ian A Smith
Next: Re: drvAscii decode string Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: drvAscii decode string Dirk Zimoch
Next: Re: drvAscii decode string Matt Rippa
