1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: drvAscii decode string
To: TECHTALK <[email protected]>
Date: Tue, 25 Apr 2006 15:54:46 +0200
Hi Ian,
you can use StreamDevice http://epics.web.psi.ch/software/streamdevice
There the format string can be "=V913 %f;59;11;0;0"
or probably "=V913 %f;%*d;%*d;%*d;%*d"
Dirk
Ian A Smith wrote:
I'm trying to read the following into an ascii analogin record:
"=V913 1.13e-04;59;11;0;0"
and to extract the 1.13e-04 or whatever. Using <%5k%f> just times out and so does <=V913%f>. Using %e makes no difference. If I read the value into a stringin record, there is no problem apart from the fact that it's a string.
Any suggestions?
TIA
-- Dr. Dirk Zimoch Swiss Light Source Paul Scherrer Institut Computing and Controls phone +41 56 310 5182 fax +41 56 310 4413
drvAscii decode string Ian A Smith
Prev: Re: drvAscii decode string Tim Mooney
Next: Re: No more CA connections? R3.14.7, 3.14.8.2, CAJ Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: drvAscii decode string Maren Purves
Next: RE: drvAscii decode string Porter, Rodney R.
