1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Sequencer embedded C code question
To: [email protected], [email protected]
Date: Thu, 29 Jun 2006 18:07:45 -0400
You are correct.
However, this is so, because I had to copy/paste in segments, and I
missed one line, that contains "}%".
So, the escaped C block is something like this:
when()
  rob=&roba; /*i dont know how to do this & wont work w/ roba as just rob*/
  v=rob[0];                /*Get first char from string*/
  wa1=strpbrk(rob, "+-");  /*Break string at +-,rest is wa1*/
  z=(float)wa1;            /*convert string to float z*/
On 6/29/06, Pete Jemian <[email protected]> wrote:
Something is not right with the fragment you sent. You start an escaped C block with "%{" but that block is never closed. So, the SNL compiler passes the rest of the code to the C compiler which does not have a definition for roba.
Try something like this:
ss string_handler {
  state stateN {
    when () {
      /* rob_pj is the string received from the device:  "1+32.23" or
"2-50.01" */
      sscanf(rob_pj, "%d%f", &chanNum, &value);
      if ( (1 <= chanNum) && (chanNum <= 5) ) {
        channel[chanNum-1] = value;
        pvPut(channel[chanNum-1]);
    } state stateN
Pete
Jiro Fujita wrote:
> Eric,
> Here is what the code looks like right now:
> program snchygrometer
> %%#include <ctype.h>
> %%#include <stdlib.h>
> %%#include <stdio.h>
>  %%char rob[10] ;
>  char *roba;
>  assign roba to "rawdata" ;
>  monitor roba ;
>  float ch1 ;
>  float ch2 ;
>  float ch3 ;
>  float ch4 ;
>  float ch5 ;
>  assign ch1 to "PV1";
>  assign ch2 to "PV2";
>  assign ch3 to "PV3";
>  assign ch4 to "PV4";
>  assign ch5 to "PV5";
>   %%int v ;
>   %%int z ;
>   %%extern char *wa1 ;
>   %%char *sign="+-" ;
> when()
> rob*/
> ss ss1 {
>   state state1 {
>      when (    v==1) {
>          ch1 = z; pvPut(ch1);
>      } state state2
>   state state2 {
>      when (    v==2) {
>          ch2 = z; pvPut(ch2);
>      } state state3
>   state state3 {
>      when (    v==3) {
>          ch3 = z; pvPut(ch3);
>      } state state4
>   state state4 {
>      when (    v==4) {
>          ch4 = z; pvPut(ch4);
>      } state state5
>   state state5 {
>      when (    v==5) {
>          ch5 = z; pvPut(ch5);
>      } state state1
> (This is the entire code).
> and here is the error we are getting:
> make[3]: Entering directory
> `/home/sysuser/epics3.14.8.2/hygrometerApp/hygrometerApp/src/O.linux-x86'
> /usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
> -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux
> -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I..
> -I../../../include/os/Linux -I../../../include
> -I/home/sysuser/epics3.14.8.2/base-3.14.8.2/../modules/soft/seq-2.0.11/include/os/Linux
> -I/home/sysuser/epics3.14.8.2/base-3.14.8.2/include/os/Linux
> -I/home/sysuser/epics3.14.8.2/modules/soft/asyn/4-6/include/os/Linux
> sncProgram.c
> ../sncExample.stt:35: warning: return type defaults to `int'
> ../sncExample.stt: In function `when':
> ../sncExample.stt:36: `roba' undeclared (first use in this function)
> ../sncExample.stt:36: (Each undeclared identifier is reported only once
> ../sncExample.stt:36: for each function it appears in.)
> ../sncExample.stt:39: pointer value used where a floating point value
> was expected
> make[3]: *** [sncProgram.o] Error 1
> make[3]: Leaving directory
> make[2]: *** [install.linux-x86] Error 2
> make[2]: Leaving directory
> `/home/sysuser/epics3.14.8.2/hygrometerApp/hygrometerApp/src'
> make[1]: *** [src.install] Error 2
> make[1]: Leaving directory
> `/home/sysuser/epics3.14.8.2/hygrometerApp/hygrometerApp'
> make: *** [hygrometerApp.install] Error 2
> What we are wondering is, why does it think rob is defaulting to int,
> when we are setting it as char??  Obviously, there is something wrong
> with array vs pointer (this is what I have been telling to my
> students), but this seems to compile without any issues outside of
> EPICS (well, the original ones we started out did, anyway).
> On 6/29/06, Eric Norum <[email protected]> wrote:
>> I'm not sure what you have changed, but the code you posted
>> originally seems
>> to be mixing up the notion of "array of characters" and "pointer to
>> character".  See my comment below:
>>   %%char rob[10] ;
>>   char *roba;
>>   monitor roba ;
>>   float ch1 ;
>>   float ch2 ;
>>   float ch3 ;
>>   float ch4 ;
>>   float ch5 ;
>>   int v ;
>>   float z ;
>>   %%char *sign="+-" ;
>>   rob=&roba                 <<<<<<<<<<<<< EVEN WITH A SEMICOLON AT
>> THE  END
>> THIS LINE MAKES NO SENSE.
>> Perhaps you could mail me your latest code??
>> Advanced Photon Source
>> Argonne National Laboratory
>> (630) 252-4793
  Pete R. Jemian, Ph.D.                <[email protected]>
  Beam line Controls and Data Acquisition, Group Leader
  Advanced Photon Source,   Argonne National Laboratory
  Argonne, IL  60439                   630 - 252 - 3189
      Education is the one thing for which people
         are willing to pay yet not receive.
Re: Sequencer embedded C code question Jiro Fujita
RE: Sequencer embedded C code question Laznovsky, Michael
Re: Sequencer embedded C code question Eric Norum
Re: Sequencer embedded C code question Pete Jemian
Prev: Re: Sequencer embedded C code question Eric Norum
Next: Re: Sequencer embedded C code question Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Sequencer embedded C code question Pete Jemian
