1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Sequencer embedded C code question
To: Jiro Fujita <[email protected]>
Cc: [email protected]
Date: Thu, 29 Jun 2006 17:08:04 -0500
Hrmph ... let me try again.
program snchygrometer
%%#include <ctype.h>
%%#include <stdlib.h>
%%#include <stdio.h>
string roba;
assign roba to "rawdata" ;
monitor roba;
evflag roba_mon;
sync   roba roba_mon;
float channel[5] ;
assign channel[0] to "PV1";
assign channel[1] to "PV2";
assign channel[2] to "PV3";
assign channel[3] to "PV4";
assign channel[4] to "PV5";
int chanNum;
float value;
ss string_handler {
 state init {
   when () {
     efClear(roba_mon);
   } state convert_my_string
state convert_my_string {
when (efTest(roba_mon)) {
/* roba is the string received from the device: "1+32.23" or "2-50.01" */
sscanf(roba, "%1d%f", &chanNum, &value);
if ( (1 <= chanNum) && (chanNum <= 5) ) {
channel[chanNum-1] = value;
pvPut(channel[chanNum-1]);
efClear(roba_mon);
Pete Jemian wrote:
Something is not right with the fragment you sent. You start an escaped C block with "%{" but that block is never closed. So, the SNL compiler passes the rest of the code to the C compiler which does not have a definition for roba.
Try something like this:
ss string_handler {
state stateN {
when () {
/* rob_pj is the string received from the device: "1+32.23" or "2-50.01" */
sscanf(rob_pj, "%d%f", &chanNum, &value);
} state stateN
Pete
Jiro Fujita wrote:
Eric,
Here is what the code looks like right now:
 %%char rob[10] ;
 char *roba;
 monitor roba ;
 float ch1 ;
 float ch2 ;
 float ch3 ;
 float ch4 ;
 float ch5 ;
 assign ch1 to "PV1";
 assign ch2 to "PV2";
 assign ch3 to "PV3";
 assign ch4 to "PV4";
 assign ch5 to "PV5";
  %%int v ;
  %%int z ;
  %%extern char *wa1 ;
  %%char *sign="+-" ;
when()
rob=&roba; /*i dont know how to do this & wont work w/ roba as just rob*/
v=rob[0]; /*Get first char from string*/
wa1=strpbrk(rob, "+-"); /*Break string at +-,rest is wa1*/
z=(float)wa1; /*convert string to float z*/
ss ss1 {
  state state1 {
     when (    v==1) {
         ch1 = z; pvPut(ch1);
     } state state2
  state state2 {
     when (    v==2) {
         ch2 = z; pvPut(ch2);
     } state state3
  state state3 {
     when (    v==3) {
         ch3 = z; pvPut(ch3);
     } state state4
  state state4 {
     when (    v==4) {
         ch4 = z; pvPut(ch4);
     } state state5
  state state5 {
     when (    v==5) {
         ch5 = z; pvPut(ch5);
     } state state1
(This is the entire code). and here is the error we are getting:
make[3]: Entering directory
`/home/sysuser/epics3.14.8.2/hygrometerApp/hygrometerApp/src/O.linux-x86'
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux
-D_REENTRANT -ansi -O3 -Wall -g -I. -I..
-I../../../include/os/Linux -I../../../include
-I/home/sysuser/epics3.14.8.2/base-3.14.8.2/../modules/soft/seq-2.0.11/include/os/Linux
-I/home/sysuser/epics3.14.8.2/base-3.14.8.2/include/os/Linux
-I/home/sysuser/epics3.14.8.2/modules/soft/asyn/4-6/include/os/Linux
sncProgram.c
../sncExample.stt:35: warning: return type defaults to `int'
../sncExample.stt: In function `when':
../sncExample.stt:36: `roba' undeclared (first use in this function)
../sncExample.stt:36: (Each undeclared identifier is reported only once
../sncExample.stt:36: for each function it appears in.)
../sncExample.stt:39: pointer value used where a floating point value
was expected
make[3]: *** [sncProgram.o] Error 1
make[3]: Leaving directory
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory
`/home/sysuser/epics3.14.8.2/hygrometerApp/hygrometerApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory
`/home/sysuser/epics3.14.8.2/hygrometerApp/hygrometerApp'
make: *** [hygrometerApp.install] Error 2
What we are wondering is, why does it think rob is defaulting to int,
when we are setting it as char??  Obviously, there is something wrong
with array vs pointer (this is what I have been telling to my
students), but this seems to compile without any issues outside of
EPICS (well, the original ones we started out did, anyway).
On 6/29/06, Eric Norum <[email protected]> wrote:
I'm not sure what you have changed, but the code you posted originally seems
to be mixing up the notion of "array of characters" and "pointer to
character". See my comment below:
  %%char rob[10] ;
  char *roba;
  monitor roba ;
  float ch1 ;
  float ch2 ;
  float ch3 ;
  float ch4 ;
  float ch5 ;
  int v ;
  float z ;
  %%char *sign="+-" ;
rob=&roba <<<<<<<<<<<<< EVEN WITH A SEMICOLON AT THE END
THIS LINE MAKES NO SENSE.
Perhaps you could mail me your latest code??
-- Eric Norum <[email protected]> Advanced Photon Source Argonne National Laboratory (630) 252-4793
 Pete R. Jemian, Ph.D.                <[email protected]>
 Beam line Controls and Data Acquisition, Group Leader
 Advanced Photon Source,   Argonne National Laboratory
 Argonne, IL  60439                   630 - 252 - 3189
     Education is the one thing for which people
        are willing to pay yet not receive.
Re: Sequencer embedded C code question Jiro Fujita
RE: Sequencer embedded C code question Laznovsky, Michael
Re: Sequencer embedded C code question Eric Norum
Re: Sequencer embedded C code question Pete Jemian
Prev: Re: Sequencer embedded C code question Jiro Fujita
Next: Re: Sequencer embedded C code question Jiro Fujita
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
