1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Measurment Computing PC104-GPIB
To: [email protected]
Date: Mon, 24 Jul 2006 11:34:19 -0500
Dear All,
We are trying to install a PC104-GPIB card onto our PC104 Linux computer (EPICS IOC). We are using a 2.6.12 kernel and 3.2.07 version of the linux-gpib software.
I compiled the linux-gpib software using the gcc compiler that comes with the kernel. I cannot get modprobe to load the device driver so I have to use "insmod" to load all the dependent modules manually. I locate the dependent files using the informations from the modules.dep file. Then I can get the device to appear in the /dev directory.
I used the "ibtest" program provided by the driver package to test the board. I can use FindLstn to find the device. I can send a device clear command to it, but I cannot get the device to listen to device specific command. For example I have an HP34401 multimeter. I can set it to remote or local mode using the "d" and "m" command provided by "ibtest", but when I send the command "READ?" through the bus I get no response from the instrument. I look at the message on the screen. It said "no listener" after I send in the "READ?" command. It gets me a little bit confuse since I can use FindLstn to locate the device.
I tried to change the original "ibwrt" to "Send" function to send the command string but it still does not help. Can somebody give me some pointers. Thanks a lot for your help?
John Lee
Prev: Re: Record fields not accessible in iocsh / database Emmanuel Mayssat
Next: Re: OPC+EPICS for Linux Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Off -Line Storage of Archiver Data - Request for Information Ernest L. Williams Jr.
Next: NCNR DAQ Position Pete Jemian
