1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Dev Asyn and Cygwin/Win IOCs , Modbus and scheduling.
To: Tech-Talk <[email protected]>
Date: Mon, 21 Aug 2006 10:06:37 -0500
    The combination of a library of clients and making good use of CA
save/Restore  looks like it will give the functionality I need.
--Bill
Pete Jemian wrote:
> Tim's message jostles my imagination.
> Can your situation be condensed to a few particular
> but different procedures involving the same set of records?
> What you describe sounds just like many of the APS beam lines.
> Maybe you would be best served by choosing from a library of
> clients, each one tailored for its specific function.
> (In APS sense, one client for XAFS, another specializes in
> diffuse scattering, ... but all use records chosen from the
> same beam line.)
> Does that help?
> Regards,
>    Pete
> Tim Mooney wrote:
>> Bill Nolan wrote:
>>  > What I am actually looking to do is well suited to SNL,
>>  >     I am scheduling the path a product will take through a production
>>  > line, starting with input bins and ending in output bins.
>>  >     Each step in the production functions independataly and is
>>  > controlled by some form of low level controller, in some cases
>> that is
>>  > an EPICS iOC, but in most cases it it a vendor supplied software
>> package
>>  > with high level hooks, typically a stringout and two Bi/Bo records.
>>  >     If the process was static or semi static I could schedule it
>> using
>>  > SNL and have no issues at all, But the process is VERY dynamic,
>> changing
>>  > as much as 3 time in an 8hr day. So I need a way to control the
>> sequence
>>  > of events that is easy and rapid to program.
>>  >     I have looked at using SEQ or SSEQ records, but the any way i
>> have
>>  > been able to think of to model the process has be requiring a new
>>  > instance of the seq record for each piece going through the
>> system. And
>>  > well, until we get a dynamic database loader that is out.
>>  >     I was considering possibly writing a GUI State editor and
>> doing some
>>  > sort of compile on the fly state programs, but that seems like,
>> well, a
>>  > lot of work.
>>  >     The real killer is that the only thing that is fixed in the
>> entire
>>  > system are the records in my database, how they connect and in what
>>  > order is entirely dynamic.
>> I'm not sure what a record corresponds with in this case, a process
>> to be performed, or a product (state) to be handled.  But let me just
>> steam on ahead anyway, and spew some possibly ignorant ideas. (If I say
>> something hilariously stupid, be sure and tell me.  I could use a good
>> laugh.)  My main point will be that links between records need not be
>> regarded as fundamentally different from other kinds of record fields.
>> They're just data that can be read and written.
>> Reprogramming every few hours sounds like a job for a client.
>> Suppose you configure your database for one particular sort of
>> product, and use a parameter save tool (e.g., casave) to save all the
>> programmed fields (all the links between records, and all the constants
>> that specify the manner in which each operation is to be done) in a
>> file.
>> Then any time you want to configure the line for that sort of product,
>> you use carestore to write the links and parameters back.  You could
>> have many different setups in this way, and change from one to another
>> in seconds.
>> What you can't do with this simplistic approach, of course, is
>> to have several different kinds of products simultaneously in the
>> production line.
Dev Asyn and Cygwin/Win IOCs , Modbus and scheduling. Bill Nolan
Re: Dev Asyn and Cygwin/Win IOCs , Modbus and scheduling. Tim Mooney
Re: Dev Asyn and Cygwin/Win IOCs , Modbus and scheduling. Bill Nolan
Re: Dev Asyn and Cygwin/Win IOCs , Modbus and scheduling. Pete Jemian
Prev: Re: looking for OSI version of epid record Tim Mooney
Next: Re: VME Bus Error handling on MVME3100 and 6100 boards Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Dev Asyn and Cygwin/Win IOCs , Modbus and scheduling. Pete Jemian
Next: RE: Dev Asyn and Cygwin/Win IOCs , Modbus and scheduling. Mark Rivers
