Dirk Zimoch wrote:
True, SLOPE conversion was added in R3.14. It is described in the Base Release Notes, but it should be documented elsewhere too. Unfortunately the Record Reference Manual is so out of date that it's embarrasing, but APS does not have the manpower to update it, and only one person has volunteered to help work on the Wiki version (which is still only for R3.13). I will make sure it's listed in appropriate places in the Application Developers Guide for R3.14.9 though. StreamDevice should have some way for the author of a protocol file to specify what the device's raw range actually is for analog records, and it should perform the calculation of ESLO and EOFF from that raw range and the EGUL+EGUF pair. Great. The axRecord.c files already set EOFF to EGUL for you, so the code in your special_linconv() routines only needs to do something like this, assuming that the raw data values range from 0 to rawRange: if (after && prec->linr == menuConvertLINEAR) {
prec->eslo = (prec->eguf - prec->egul) / rawRange;
}- Andrew -- There is considerable overlap between the intelligence of the smartest bears and the dumbest tourists -- Yosemite National Park Ranger
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
