1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Naming conventions for devices and Epics records
To: tech talk <[email protected]>
Date: Fri, 17 Nov 2006 11:19:16 -0500
Eric,
Following up on Kay's comments, a problem here at SNS has been that
there has not been a consequence for not following the convention.
Because the emphasis was always on construction and beam on target,
"bad" names have been allowed and now are deeply entrenched in our
controls system.  Updating them is very difficult when you consider the
IOCs, control screens, relational database and supporting application,
etc.  Updating all of these situations is time consuming but doable.
The biggest problem is, however, the archiver.  I am not an expert by
any means but I haven't been told by anyone that there is a non-clunky
way to change a PV name and have archived data continue to stay related.
I would suggest making adherence to your convention a part of employees
expected performance.  A tool, as mentioned by Kay, would help.
If I can find our official SNS Naming document, I'll forward it to you.
I have hard copy but our document control has misnamed it.  I kidding
but the electronic copy is illusive.  These two links provide a little
information on the SNS convention.
https://ics-web1.sns.ornl.gov/STANDARDS/Naming%20Conventions%20Instructi
onal%20Document.pdf
http://ics-web1.sns.ornl.gov/CONTROLS/sysSubsys.html
Dave
-----Original Message-----
Sent: Friday, November 17, 2006 10:25 AM
To: tech talk
Subject: Re: Naming conventions for devices and Epics records
On Nov 17, 2006, at 09:49 , Lecorche Eric wrote:
> Hi,
> As we are starting our new Spiral2 project, I am now gathering some
> pieces of information in order to establish naming conventions both
> for devices and Epics records and taking into account habits
> inherited from the existing Ganil installation.
> I already got a document from Diamond describing such naming
> conventions but I would be interested by having others coming from
> other labs.
> Can some labs send me some documents relevant for this topic ?
Hello Eric:
Whatever you do, write your naming standard
like a computer language definition, for example using BNF:
  <name> ::= <system> ":" <device> ":" <signal>
  <system> ::= <system-id> <system-instance> "-" <subsystem-id>
<subsystem-instance>
  <system-instance> ::= "" | "_" <instance>
  <instance> ::= <integer> | <integer> <a-to-z>
An additional, verbose, more human readable explanation is nice,
but allow no misconception about the use of upper/lower case, '_' or
or the structure of instance numbers.
This asserts that you get parsable names, which you'll need
for name-related tools. Actually, try to write a name parser right away,
for example in perl, to
a) check if your naming standard allows parsing
b) have such a tool to check names as soon as the first person tries
    to define the first process variable.
That way, you might avoid ending up with names like
DTL_Xyz:Gadget105:Value, wondering:
Is this the 105th gadget of the overall drift tube linac, or the 5th
gadget on DTL #1?
How do I write a regular expression that gives me all the devices on
DTL #2?
-Kay
Name Aliasing Dalesio, Leo `Bob`
Re: Naming conventions for devices and Epics records Kay-Uwe Kasemir
RE: Naming conventions for devices and Epics records Strong, William Herb
Prev: Re: Naming conventions for devices and Epics records Pete Jemian
Next: Name Aliasing Dalesio, Leo `Bob`
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Naming conventions for devices and Epics records Kay-Uwe Kasemir
