1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Naming conventions for devices and Epics records
To: tech talk <[email protected]>
Date: Fri, 17 Nov 2006 11:49:52 -0500
Hello:
It's Friday, so I can't help but add a few more comments.
When you compare the link that Dave sent,
https://ics-web1.sns.ornl.gov/STANDARDS/Naming%20Conventions% 20Instructional%20Document.pdf
to the BESSY docs, you'll see things like underscores that are allowed,
but not required in some places.
Earlier SNS naming documents contained phrases like "use upper/lower case
and underscores however you like to improve readability".
Good examples for a non-standard, resulting in long names, maybe readable,
but definitely hard to parse. Worst are probably our instance numbers:
"105" = 105th instance, or 5th instance on 1st system
"05b" = 2nd instance on 5th system
"_65kV" = the system that handles 65*10^3 Volts
- I think, because 65kV suggests a voltage.
For a name parser, it could also be the 65th instance
on the 'kV' system.
"_FE65kV" = the system that handles 65*10^3 Volts on the front-end?
"208t303" = no idea
RE: Naming conventions for devices and Epics records Gurd, Pamela A.
RE: Naming conventions for devices and Epics records Purcell, J. David
Prev: Re: Naming conventions for devices and Epics records Luedeke Andreas
Next: RE: Naming conventions for devices and Epics records Strong, William Herb
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Name Aliasing Gurd, Pamela A.
Next: RE: Naming conventions for devices and Epics records Gurd, Pamela A.
