1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: wxPython timer and KEK CaPython314 cause core dump
To: [email protected]
Cc: [email protected]
Date: Thu, 14 Dec 2006 11:30:21 +0900
Zhong Ren wrote:
> Dear Noboru,
> Thank you.  I must say the KEK CaPython314 is very easy to use.
> I am not surprised that your little test below won't crash,
> since it does not contain a wx.Timer.  In order to repeat my
I see.
Each time I started the code, it crashes after some period but the
life-time varies time-to-time. Error message also changes.
I suspect interrupt caused by a timer breaks "Global-Interpreter-Lock"
mechanism, on which CA-Python interface relies on.
SWIG, a tool used in wxPython, supports threads and GIL but I'm not
quite sure if wxPython binary I got from the net uses this feature or
not. I want to check if this options affect the phenomena but it may
take sometime.
> crash, a wx.Timer must be constructed, it must be bound to a
> onTimer function, and it must be started.  Using
> threading.Timer instead of wx.Timer will not cause the crash.
In my environment, threading.Timer also causes the crash. Whoom.
>  I cannot tell who is guilty, wx.Timer or CaPython314.  I also
> have the feeling that Python 2.5 may be the problem.
When I get the new result, I will report it on this mailing list.
Noboru
begin:vcard
fn:Noboru Yamamoto
n:Yamamoto;Noboru
email;internet:[email protected]
tel;work:+81-29-864-1171, ext. 5309
tel;fax:+81-29-864-0321
x-mozilla-html:FALSE
version:2.1
end:vcard
Re: wxPython timer and KEK CaPython314 cause core dump Zhong Ren
Prev: Re: [Fwd: EPICS Base @ HP-UX: Volunteers wanted] Billy Adams
Next: Re: [Fwd: EPICS Base @ HP-UX: Volunteers wanted] Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: wxPython timer and KEK CaPython314 cause core dump Zhong Ren
Next: next EPICS meeting at DESY in April 2007 Matthias Clausen
