1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Fwd: EPICS Base @ HP-UX: Volunteers wanted]
To: "Kazuro FURUKAWA" <[email protected]>
Cc: "EPICS tech-talk" <[email protected]>, "Andrew Johnson" <[email protected]>
Date: Wed, 13 Dec 2006 16:52:53 -0500
Kazuro,
We still have four HP-UX EPICS computers left at NASA-Langley Research Center running EPICS R3.12.2. There are no plans to upgrade one of them. We will continue to need this one!
I am in the process of upgrading three of them to newer Fedora Core 6 Linux computers running EPICS R3.14.8.2. However, at least temporarily, we will need to keep EPICS R3.12.2 on at least one of the three HP-UX computers for IOC software development.
Billy R. Adams
Raytheon
757-864-5934
----- Original Message ----- From: "Kazuro FURUKAWA" <[email protected]>
To: "Andrew Johnson" <[email protected]>
Cc: "EPICS tech-talk" <[email protected]>; "Kazuro FURUKAWA" <[email protected]>
Sent: Wednesday, December 13, 2006 7:55 AM
Dear Andrew and Ralph,
On Tue, 12 Dec 2006 15:01:41 JST, Andrew Johnson <[email protected]> wrote;
In order that Ralph's Call For Volunteers receives as wide an audience
as possible, I'm forwarding this message to tech-talk (apologies to the
core-talk folks who've already seen it once).  If your site expects to
need to run EPICS R3.14.9 on HP-UX, you should have someone step up now
or we may have to drop HP-UX from the list of architectures officially
supported by EPICS.
Are we the only HP-UX EPICS users on the planet?! I'll look into our resource, but maybe we don't need newer versions of EPICS on HP-UX. So... At KEKB, although I keep two HP-UX machines for some reason and I have installed R3.14.8.2, the versions of HP-UXen are V10.20 and V11.0 ... They are old and normally run R3.13 clients.
Instead, we may be interested in keeping Tru64 and FreeBSD.
Our main client platforms are Darwin and Tru64.  We will re-
introduce Linux machines again, partially to replace HP-UX.  Other
facilities like Linac, Photon-Factory and J-PARC are using Linux
as the main EPICS clients.
FYI, R3.14.8.2 on HP-UX V11.0 mostly works for me.  Somehow,
startup/EpicsHostArch.pl did not work.  Other than that, I
simply modified SHRLIB_SEARCH_FULLPATHDIRS in
CONFIG_SITE.Common.hpux-parisc, and it worked.  Thanks to Ralph!!
Regards, Kazuro.
-------- Original Message --------
Subject: EPICS Base @ HP-UX: Volunteers wanted
Date: Tue, 12 Dec 2006 15:27:06 +0100
Organization: BESSY
To: EPICS Core Talk <[email protected]>
Hello everyone,
trying to resolve the situation with an outdated C++ compiler crashing
on the EPICS sources, I found out that BESSY doesn't seem to be able to
support testing Base on HP-UX any longer.
We are in the middle of converting to Linux, the software on our few
remaining HP-UX machines has been in frozen state for a while, so asking
for an update of a compiler to test a software that is not going to be
used on that platform
... sounds a lot like asking someone to waste time to be able to waste
more time.
I know we intended to keep HP-UX supported for 3.14 and I know there are
others still using HP machines, so I'm not feeling too happy with this
issue. In any case I would like to keep the HP-UX configuration files
around for a little longer.
Well, I'm throwing the ball high up in the air and start running ....
maybe one of the KEK colleagues (the only remaining HP users as far as I
know) is able to catch it?!
I'm definitely willing to continue helping with ideas and suggestions,
if someone takes over. No question. But without a current system and
compiler I'm not able to compile nor test.
Sorry -
Ralph
-- There is considerable overlap between the intelligence of the smartest bears and the dumbest tourists -- Yosemite National Park Ranger
----- Kazuro FURUKAWA <[email protected]> Linac&KEKB, High Energy Accelerator Research Organization (KEK), Japan
Re: [Fwd: EPICS Base @ HP-UX: Volunteers wanted] Ralph Lange
Re: [Fwd: EPICS Base @ HP-UX: Volunteers wanted] Kazuro FURUKAWA
Prev: Re: [Fwd: EPICS Base @ HP-UX: Volunteers wanted] Matt Bickley
Next: Re: wxPython timer and KEK CaPython314 cause core dump Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: [Fwd: EPICS Base @ HP-UX: Volunteers wanted] Ralph Lange
