1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Fwd: EPICS Base @ HP-UX: Volunteers wanted]
To: Kazuro FURUKAWA <[email protected]>
Cc: Andrew Johnson <[email protected]>, EPICS tech-talk <[email protected]>
Date: Thu, 14 Dec 2006 11:48:14 +0900
As Kazuro already reported, KEKB&PF-AR/KEK are in the process of
replacing HP-UX hosts with Linux/MacOSX/True64(OSF1-Alpha) hosts.
On HP-UX, EPICS 3.13.6 or older are still used for operation.
For Tornado/VxWorks, Sun/Solaris workstation has introduced.
In J-PARC, the project I currently working on, HP-UX machines are thrown
away sometime before and uses mostly Linux for OPI side.
(Personally, I test EPICS software on MacBook, but it is not officially
supported in J-PARC)
So, I think, it will not be a big issue for KEK to drop a support for
HP-UX in the future versions of EPICS.
Noboru
Kazuro FURUKAWA wrote:
> Dear Andrew and Ralph,
>>>> On Tue, 12 Dec 2006 15:01:41 JST,  Andrew Johnson <[email protected]> wrote;
>> In order that Ralph's Call For Volunteers receives as wide an audience
>> as possible, I'm forwarding this message to tech-talk (apologies to the
>> core-talk folks who've already seen it once).  If your site expects to
>> need to run EPICS R3.14.9 on HP-UX, you should have someone step up now
>> or we may have to drop HP-UX from the list of architectures officially
>> supported by EPICS.
> Are we the only HP-UX EPICS users on the planet?!  I'll look into
> our resource, but maybe we don't need newer versions of EPICS on
> HP-UX.  So...  At KEKB, although I keep two HP-UX machines for
> some reason and I have installed R3.14.8.2, the versions of HP-UXen
> are V10.20 and V11.0 ...  They are old and normally run R3.13
> clients.
> Instead, we may be interested in keeping Tru64 and FreeBSD.
> Our main client platforms are Darwin and Tru64.  We will re-
> introduce Linux machines again, partially to replace HP-UX.  Other
> facilities like Linac, Photon-Factory and J-PARC are using Linux
> as the main EPICS clients.
> FYI, R3.14.8.2 on HP-UX V11.0 mostly works for me.  Somehow,
> startup/EpicsHostArch.pl did not work.  Other than that, I
> simply modified SHRLIB_SEARCH_FULLPATHDIRS in
> CONFIG_SITE.Common.hpux-parisc, and it worked.  Thanks to Ralph!!
> Regards, Kazuro.
>> -------- Original Message --------
>> Subject: EPICS Base @ HP-UX: Volunteers wanted
>> Date: Tue, 12 Dec 2006 15:27:06 +0100
>> From: Ralph Lange <[email protected]>
>> Organization: BESSY
>> To: EPICS Core Talk <[email protected]>
>> Hello everyone,
>> trying to resolve the situation with an outdated C++ compiler crashing
>> on the EPICS sources, I found out that BESSY doesn't seem to be able to
>> support testing Base on HP-UX any longer.
>> We are in the middle of converting to Linux, the software on our few
>> remaining HP-UX machines has been in frozen state for a while, so asking
>> for an update of a compiler to test a software that is not going to be
>> used on that platform
>> ... sounds a lot like asking someone to waste time to be able to waste
>> more time.
>> I know we intended to keep HP-UX supported for 3.14 and I know there are
>> others still using HP machines, so I'm not feeling too happy with this
>> issue. In any case I would like to keep the HP-UX configuration files
>> around for a little longer.
>> Well, I'm throwing the ball high up in the air and start running ....
>> maybe one of the KEK colleagues (the only remaining HP users as far as I
>> know) is able to catch it?!
>> I'm definitely willing to continue helping with ideas and suggestions,
>> if someone takes over. No question. But without a current system and
>> compiler I'm not able to compile nor test.
>> Sorry -
>> Ralph
>> There is considerable overlap between the intelligence of the smartest
>> bears and the dumbest tourists -- Yosemite National Park Ranger
>  Linac&KEKB,  High Energy Accelerator Research Organization (KEK), Japan
begin:vcard
fn:Noboru Yamamoto
n:Yamamoto;Noboru
email;internet:[email protected]
tel;work:+81-29-864-1171, ext. 5309
tel;fax:+81-29-864-0321
x-mozilla-html:FALSE
version:2.1
end:vcard
Re: [Fwd: EPICS Base @ HP-UX: Volunteers wanted] Kazuro FURUKAWA
Prev: Re: wxPython timer and KEK CaPython314 cause core dump Noboru Yamamoto
Next: Re: [Fwd: EPICS Base @ HP-UX: Volunteers wanted] Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Fwd: EPICS Base @ HP-UX: Volunteers wanted] Ralph Lange
Next: Problems with database breakpoint routines. Rees, NP (Nick)
