1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem with compiling Channel Archiver
To: <[email protected]>
Date: Fri, 16 Mar 2007 07:58:02 -0500
Lets try emailing this again-
I'm trying to compile the Channel Archiver program, and it fails with
this error stream:
make[4]: Entering directory
`/usr/local/EPICS/extensions/src/ChannelArchiver/LibIO/O.linux-x86'
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux
-D_REENTRANT -ansi  -g  -Wall     -D ARCH_VERSION=2 -D ARCH_RELEASE=9 -D
ARCH_PATCH=2 -D ARCH_VERSION_TXT=\"2.9.2\" -IOME/include
-I/usr/local/EPICS/base/include -I/usr/local/EPICS/base/include/os/Linux
-I/usr/local/xerces-c-src2_4_0/include      -g -fPIC -I. -I..
-I/usr/local/EPICS/include/os/Linux -I/usr/local/EPICS/include
-I/usr/local/EPICS/base/include/os/Linux -I/usr/local/EPICS/base/include
../DataFile.cpp
../DataFile.h:130: error: 'DataHeaderIterator' does not name a type
../DataFile.h:138: error: 'DataHeaderIterator' has not been declared
../DataFile.h: In member function 'bool
DataHeaderIterator::addNewValue(const BinValue&, bool)':
../DataFile.h:183: error: no matching function for call to
'DataFile::addNewValue(DataHeaderIterator&, const BinValue&, bool&)'
../DataFile.h:138: note: candidates are: bool
DataFile::addNewValue(int&, const BinValue&, bool)
../DataFile.cpp: At global scope:
../DataFile.cpp:159: error: prototype for 'bool
DataFile::addNewValue(DataHeaderIterator&, const BinValue&, bool)' does
not match any in class 'DataFile'
../DataFile.h:138: error: candidate is: bool
../DataFile.cpp:200: error: no 'DataHeaderIterator
DataFile::addHeader(DataHeader&, const CtrlInfo&, DataHeaderIterator*)'
member function declared in class 'DataFile'
make[4]: *** [DataFile.o] Error 1
make[4]: Leaving directory
make[3]: *** [buildInstall.linux-x86] Error 2
make[3]: Leaving directory
`/usr/local/EPICS/extensions/src/ChannelArchiver/LibIO'
make[2]: *** [LibIO.buildInstall] Error 2
make[2]: Leaving directory
`/usr/local/EPICS/extensions/src/ChannelArchiver'
make[1]: *** [ChannelArchiver.buildInstall] Error 2
make[1]: Leaving directory `/usr/local/EPICS/extensions/src'
make: *** [src.buildInstall] Error 2
I downloaded 'archive.tgz' from the Channel Archiver page.
David Dudley
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
Prev: Re: epics compiling problem ʦê»Àñ
Next: Re: Problem with compiling Channel Archiver David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: epics compiling problem Kate Feng
