OK,
I'm running Gentoo Linux.
The gcc compiler gives me:
gcc --version
gcc (GCC) 4.1.1 (Gentoo 4.1.1-r3)
Copyright (C) 2006 Free Software Foundation, Inc.
I'm building SDDS, StripTool, alh, and medm in the extensions directory, all of which build with no errors. Also have edm, but I have to build it separately for some reason.
I downloaded archiver.tgz from the extensions page, and when I unpack the 'ChannelArchiver' package and rebuild, it rebuilds the others fine, but fails on 'ChannelArchiver'.
I did a grep on HOME, but the only references I can find to it are correct (no $HOME, but I have $(HOME)) in the config and configure directories.
In the ChannelArchiver make.cfg file, I did find $HOME, however. Changing that to $(HOME) fixed the 'IOME' problem and gave me all the includes, but did not fix the problem with compiling the package.
Adding the 'class' keyword to line 130 of the 'LibIO/DataFile.h' file did fix that problem.
Now, I have an error (much farther down in compiling) that says:
/usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -ansi -g -Wall -D ARCH_VERSION=2 -D ARCH_RELEASE=9 -D ARCH_PATCH=2 -D ARCH_VERSION_TXT=\"2.9.2\" -I/home/daviddu/include -I/usr/local/EPICS/base/include -I/usr/local/EPICS/base/include/os/Linux -I/usr/local/xerces-c-src2_4_0/include -I${prefix}/include -g -I. -I.. -I/usr/local/EPICS/include/os/Linux -I/usr/local/EPICS/include -I/usr/local/EPICS/base/include/os/Linux -I/usr/local/EPICS/base/include -I/usr/local/EPICS/include/os/Linux -I/usr/local/EPICS/include ../main_standalone.cpp
../main_standalone.cpp:13:26: error: xmlrpc_abyss.h: No such file or directory
../main_standalone.cpp: In function 'int main(int, char**)':
../main_standalone.cpp:70: error: 'XMLRPC_SERVER_ABYSS_NO_FLAGS' was not declared in this scope
../main_standalone.cpp:70: error: 'xmlrpc_server_abyss_init' was not declared in this scope
../main_standalone.cpp:81: error: 'xmlrpc_server_abyss_add_method_w_doc' was not declared in this scope
../main_standalone.cpp:85: error: 'xmlrpc_server_abyss_run' was not declared in this scope
make[2]: *** [main_standalone.o] Error 1
make[2]: Leaving directory `/usr/local/EPICS/extensions/src/ChannelArchiver/XMLRPCServer/O.linux-x86'
make[1]: *** [install.linux-x86] Error 2
make[1]: Leaving directory `/usr/local/EPICS/extensions/src/ChannelArchiver/XMLRPCServer'
make: *** [XMLRPCServer.install] Error 2
David
>>> Kay-Uwe Kasemir <[email protected]> 3/16/2007 8:50 AM >>>
Hi:
> Lets try emailing this again-
When did you try first?
> I'm trying to compile the Channel Archiver program, and it fails with
> this error stream:
> make[4]: Entering directory
> `/usr/local/EPICS/extensions/src/ChannelArchiver/LibIO/O.linux-x86'
> ARCH_RELEASE=9 -D
> ARCH_PATCH=2 -D ARCH_VERSION_TXT=\"2.9.2\" -IOME/include
> Linux
> -I/usr/local/xerces-c-src2_4_0/include -g -fPIC -I. -I..
> include
> ../DataFile.cpp
What's the "-IOME/include"?
Different OS etc., but for what it's worth, this is what I get:
/usr/bin/c++ -c -DUNIX -Ddarwin -ansi -g -Wall -D
ARCH_VERSION=2 -D ARCH_RELEASE=12 -D ARCH_PATCH=0 -D ARCH_VERSION_TXT=
\"2.12.0\" -I/Kram/epics/R3.14.8.2/base/include -I/Kram/epics/
R3.14.8.2/base/include/os/Darwin -I/usr/local/include -fno-common
-fPIC -I. -I.. -I../../../../include/os/Darwin -I../../../../include -
I/Kram/epics/R3.14.8.2/base/include/os/Darwin -I/Kram/epics/R3.14.8.2/
base/include -I../../../../include/os/Darwin -I../../../../
include -I/opt/local/include -I/sw/include ../DataFile.cpp
So I don't get the equivalent to "-IOME".
You probable added an "-I$HOME/..." instead of "-I$(HOME)/..." to
some config file.
> ../DataFile.h:130: error: 'DataHeaderIterator' does not name a type
> ../DataFile.h:138: error: 'DataHeaderIterator' has not been declared
The DataFile and DataHeaderIterator classes refer to each other,
so it's a chicken and egg kind of problem.
What compiler are you using?
With g++ 3.2.3 and 4.0 I see no such problems.
What if you change the Datafile.h line 130 from
DataHeaderIterator addHeader(
to
class DataHeaderIterator addHeader(
Or move the
friend class DataHeaderIterator
from line 141 to just before line 130?
-Kay
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
Problem with compiling Channel Archiver David Dudley
Re: Problem with compiling Channel Archiver Kay-Uwe Kasemir
<2007>
2025
2026
<2007>
2025
2026
