1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem with compiling Channel Archiver
To: David Dudley <[email protected]>
Cc: [email protected]
Date: Fri, 16 Mar 2007 10:44:25 -0400
On Mar 16, 2007, at 10:25 , David Dudley wrote:
Adding the 'class' keyword to line 130 of the 'LibIO/DataFile.h' file did fix that problem.
OK.
Now, I have an error (much farther down in compiling) that says:
The good news is that you're about as far down with compiling as you'll get.
/usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS - D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux - D_REENTRANT -ansi -g -Wall -D ARCH_VERSION=2 -D ARCH_RELEASE=9 - D ARCH_PATCH=2 -D ARCH_VERSION_TXT=\"2.9.2\" -I/home/daviddu/include - I/usr/local/EPICS/base/include -I/usr/local/EPICS/base/include/os/ Linux -I/usr/local/xerces-c-src2_4_0/include -I${prefix}/ include -g -I. -I.. -I/usr/local/EPICS/include/os/Linux -I/usr/ local/EPICS/include -I/usr/local/EPICS/base/include/os/Linux -I/usr/ local/EPICS/base/include -I/usr/local/EPICS/include/os/Linux -I/usr/ local/EPICS/include ../main_standalone.cpp
../main_standalone.cpp:13:26: error: xmlrpc_abyss.h: No such file or directory
Following the admittedly lengthy stuff in the manual's Setup/ Installation section,
I end up with /usr/local/include/xmlrpc_abyss.h.
Do you have that?
In addition, the program "xmlrpc-c-config" should be on the PATH.
Is it?
With that,
  ChannelArchiver/XMLRPCServer/xmlrpc-config-wrapper server-flags
should produce something like "-I/usr/local/include".
Does it?
Or does that result in the "-I${prefix}/include" which probably
won't work?
-Kay
Prev: Re: Problem with compiling Channel Archiver David Dudley
Next: Re: Problem with compiling Channel Archiver David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
