1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS thread problem on cygwin-x86
To: "Eric Norum" <[email protected]>
Cc: <[email protected]>
Date: Fri, 27 Apr 2007 14:37:13 -0500
Hi Eric,
Thanks for helping with this, sorry I misunderstood your question.
The answer is that YES it does fix the problem to put the
epicsThreadSleep(.001) in the start_routine function in osdThread.c.
Without that call to epicsThreadSleep I added print statements in
epicsThreadCreate in that same file so I could see the status returned
by pthread_create().
epicsThreadId epicsThreadCreate(const char *name,
    unsigned int priority, unsigned int stackSize,
    EPICSTHREADFUNC funptr,void *parm)
    epicsThreadOSD *pthreadInfo;
    int status;
    sigset_t blockAllSig, oldSig;
    epicsThreadInit();
    assert(pcommonAttr);
    sigfillset(&blockAllSig);
    pthread_sigmask(SIG_SETMASK,&blockAllSig,&oldSig);
    pthreadInfo = init_threadInfo(name,priority,stackSize,funptr,parm);
    if(pthreadInfo==0) return 0;
    pthreadInfo->isEpicsThread = 1;
    setSchedulingPolicy(pthreadInfo,SCHED_FIFO);
    pthreadInfo->isFifoScheduled = 1;
printf("Calling pthread_create\n");
    status = pthread_create(&pthreadInfo->tid,&pthreadInfo->attr,
                start_routine,pthreadInfo);
printf("pthread_create status=%d\n", status);
    if(status==EPERM){
        /* Try again without SCHED_FIFO*/
        free_threadInfo(pthreadInfo);
        pthreadInfo =
printf("Calling pthread_create without SCHED_INFO\n");
printf("pthread_create without SCHED_INFO status=%d\n", status);
Here is the output:
epics> threadTest 1
pthread_create status=0
Sleeping 5 seconds
epics>
epics>
epics> threadTest 0
pthread_create status=11
pthread_create error Resource temporarily unavailable
Segmentation fault (core dumped)
So pthread_create is returning status=11 (EAGAIN) when things mess up.
Any idea what this means and how to fix it?  And why is the error
causing a seg fault, since it did simply return an error.
rivers@Subaru /corvette/home/epics/devel/threadTest/iocBoot/iocexample
> -----Original Message-----
> From: Eric Norum [mailto:[email protected]]
> Sent: Friday, April 27, 2007 2:10 PM
> To: Mark Rivers
> Cc: [email protected]
> Subject: Re: EPICS thread problem on cygwin-x86
> On Apr 27, 2007, at 1:58 PM, Mark Rivers wrote:
> > Eric,
> > 1) Does putting the epicsThreadSleep(.001); into the thread wrapper
> > function that actually invokes the EPICS thread fix things?
> > No.  I have simplified the program even more, eliminating the
> > epicsEvent.  I just spawn a thread that either returns
> immediately or
> > sleeps for .001 second.  The wrapper function now sleeps
> for 5 seconds
> > after spawning the thread.  It still behaves the same, i.e. if the
> > spawned thread sleeps for .001 second all is well, and the calling
> > function sleeps for 5 seconds and prints a message. If it does not
> > sleep
> > then it crashes.
> I think that I wasn't clear enough about where I meant for the delay
> to go.
> Here's the code in /src/libCom/osi/os/posix/osdThread.c which
> I meant
> when I referred to the 'wrapper' routine:
> static void * start_routine(void *arg)
>      epicsThreadOSD *pthreadInfo = (epicsThreadOSD *)arg;
>      int status;
>      int oldtype;
>      sigset_t blockAllSig;
>      pthread_sigmask(SIG_SETMASK,&blockAllSig,NULL);
>      status = pthread_setspecific(getpthreadInfo,arg);
>      checkStatusQuit(status,"pthread_setspecific","start_routine");
>      status = pthread_setcanceltype
> (PTHREAD_CANCEL_ASYNCHRONOUS,&oldtype);
>      checkStatusQuit(status,"pthread_setcanceltype","start_routine");
>      status = mutexLock(&listLock);
>      checkStatusQuit(status,"pthread_mutex_lock","start_routine");
>      ellAdd(&pthreadList,&pthreadInfo->node);
>      pthreadInfo->isOnThreadList = 1;
>      status = pthread_mutex_unlock(&listLock);
>      checkStatusQuit(status,"pthread_mutex_unlock","start_routine");
>      (*pthreadInfo->createFunc)(pthreadInfo->createArg);
>      epicsExitCallAtThreadExits ();
>      return(0);
> Does putting the delay just before the free_threadInfo call
> fix things?
> > 2) Have you tried running this under gdb to see where the crash
> > occurs?
> > I have found that gdb under Cygwin does not run the threaded EPICS
> > applications at all.  Maybe I'm doing something wrong, but what
> > works on
> > Linux does not work on Cygwin.  Furthermore, Cygwin does
> not produce a
> > useful core file.  It produces a file called, in this case
> > "threadTest.exe.stackdump", but it simply contains:
> > $ cat threadTest.exe.stackdump
> > Exception: STATUS_ACCESS_VIOLATION at eip=004A05B6
> > eax=DF0DF046 ebx=004E6F60 ecx=6112CB58 edx=005A2DC0 esi=005A2DC0
> > edi=610E30A0
> > ebp=0022EDD8 esp=0022EDD4
> > program=j:\epics\devel\threadTest\bin\cygwin-x86\threadTest.exe, pid
> > 4028, thread main
> > cs=001B ds=0023 es=0023 fs=003B gs=0000 ss=0023
> > Stack trace:
> > Frame     Function  Args
> > 0022EDD8  004A05B6  (004E6F60, 005A2DC0, 0022EE08, 005A2DC8)
> > 0022EDF8  004918A7  (610E30A0, 004D94F4, 004D9747, 6110A4F0)
> > 0022EE28  0049220E  (004C9438, 0000000A, 00020000, 00401520)
> > 0022EE48  00401593  (00543BD8, 0022EEE8, 00000000, 005407A4)
> > 0022EEF8  00418070  (61157780, FFFFFFFF, 00000000, 004015F3)
> > 0022EF18  0040161E  (00000002, 61157668, 00540090, 77FA88F0)
> > 0022EFD8  61004DD2  (0022EFF0, 00000000, 0022F221, 33323430)
> > 0022FF88  6100594F  (00000000, 00000000, 00000000, 00000000)
> > End of stack trace
> Hmmmmm...
> not too useful.
> Eric Norum <[email protected]>
> Advanced Photon Source
> Argonne National Laboratory
> (630) 252-4793
Re: EPICS thread problem on cygwin-x86 Benjamin Franksen
Re: EPICS thread problem on cygwin-x86 Eric Norum
Prev: Re: EPICS thread problem on cygwin-x86 Eric Norum
Next: Controls Positions at SNS Gurd, David P.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EPICS thread problem on cygwin-x86 Benjamin Franksen
