On Friday 27 April 2007 21:37, Mark Rivers wrote:
> epics> threadTest 1
> Calling pthread_create
> pthread_create status=0
> Sleeping 5 seconds
> epics>
> epics>
> epics> threadTest 0
> pthread_create status=11
> pthread_create error Resource temporarily unavailable
> Segmentation fault (core dumped)
> So pthread_create is returning status=11 (EAGAIN) when things mess up.
> Any idea what this means and how to fix it? And why is the error
> causing a seg fault, since it did simply return an error.
Hi Mark,
you probably know this but just in case: EAGAIN is the hallmark of
cheap-and-dirty system design. In Unix, when a system call gets interrupted
by a signal and must be restarted, the system doesn't automatically restart
the call. Instead the system call returns the error code EAGAIN. Thus, in
principle, every such call must be wrapped (by the user!) in a loop like
this
do {
ret = syscall(...);
} while (ret != EAGAIN);
How this relates to the concrete problem you are having I can't say, other
than that it seems the reason in this case is not a signal but rather a
'temporarily unavailable resource'.
BTW, since the status you get is not EPERM, the crash must happen some where
inside the rest of the wrapper routine (the part which you did not quote),
which is
static void * start_routine(void *arg)
/*...error not in this part...*/
if(status) {
free_threadInfo(pthreadInfo);
return 0;
status = pthread_sigmask(SIG_SETMASK,&oldSig,NULL);
checkStatusOnce(status,"pthread_sigmask");
return(pthreadInfo);
that is, either in free_threadInfo() or pthread_sigmask(). (I am assuming
the crash really happens inside epicsThreadCreate().)
HTH
Ben
- RE: EPICS thread problem on cygwin-x86 Mark Rivers
duplicate emails? Laznovsky, Michael
RealPlayer complains of file not found for Getting Started with EPICS Lecture Series Dayle Kotturi
<2007>
2025
2026
[Fwd: New for Argonne National Laboratory Employees - Your Quarterly Newsletter from National Instruments] Ned D. Arnold
<2007>
2025
2026
