Sounds like you're missing Till's 'BSP Extensions' library.
The EPICS build system fragment configure/os/CONFIG.Common.RTEMS-
mvme2100 should probably be changed add -lbspExt to the list of
libraries.
On May 2, 2007, at 1:34 PM, John Sinclair wrote:
I am beginning to do some VME access from an EPICS application on
RTEMS. As a first check, I
added a bit of vme access code to a device support function only to
see if the application would
build. The code merely calls devRegisterAddress using atVMEA16 as
the address type.
The build fails with the following errors:
/home/sinclair/rtemsEpics/supTop/R3.14.9/base/lib/RTEMS-mvme2100//
libCom.a(devLibOSD.o): In function `rtmsDevInit':
../../../src/libCom/osi/os/RTEMS/devLibOSD.c:105: undefined
reference to `bspExtInit'
libCom.a(devLibOSD.o): In function `rtmsDevWriteProbe':
../../../src/libCom/osi/os/RTEMS/devLibOSD.c:253: undefined
reference to `bspExtMemProbe'
libCom.a(devLibOSD.o): In function `rtmsDevReadProbe':
../../../src/libCom/osi/os/RTEMS/devLibOSD.c:234: undefined
I have built an application using the generic RTEMS build scheme
(no EPICS) that accesses the VMEbus without problems.
Any ideas as to what configuration pieces are missing?
- John Sinclair
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
- Re: EPICS on RTEMS John Sinclair
- EPICS on RTEMS John Sinclair
EDM using -ctl Michele Joyce
<2007>
2025
2026
<2007>
2025
2026
ANJ, 10 Nov 2011 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
