I guess I was missing this piece. I had to manually copy the library
(could have soft-linked it) and add
USR_LIBS += bspExt
to the makefile. But then, since make is being instructed (why?) to also
build the system on the host (linux-x86), this library
was missing for the linux build. I created a dummy one using ar and the
build finally succeeded.
Is this the "correct" way to do EPICS with RTEMS or do I somehow have
things half-configured?
- John Sinclair
Eric Norum wrote:
Sounds like you're missing Till's 'BSP Extensions' library.
The EPICS build system fragment
configure/os/CONFIG.Common.RTEMS-mvme2100 should probably be changed
add -lbspExt to the list of libraries.
On May 2, 2007, at 1:34 PM, John Sinclair wrote:
I am beginning to do some VME access from an EPICS application on
RTEMS. As a first check, I
added a bit of vme access code to a device support function only to
see if the application would
build. The code merely calls devRegisterAddress using atVMEA16 as the
address type.
The build fails with the following errors:
/home/sinclair/rtemsEpics/supTop/R3.14.9/base/lib/RTEMS-mvme2100//libCom.a(devLibOSD.o):
In function `rtmsDevInit':
../../../src/libCom/osi/os/RTEMS/devLibOSD.c:105: undefined reference
to `bspExtInit'
In function `rtmsDevWriteProbe':
../../../src/libCom/osi/os/RTEMS/devLibOSD.c:253: undefined reference
to `bspExtMemProbe'
In function `rtmsDevReadProbe':
../../../src/libCom/osi/os/RTEMS/devLibOSD.c:234: undefined reference
to `bspExtMemProbe'
I have built an application using the generic RTEMS build scheme (no
EPICS) that accesses the VMEbus without problems.
Any ideas as to what configuration pieces are missing?
- John Sinclair
--Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
smime.p7s
Description: S/MIME Cryptographic Signature
- Re: EPICS on RTEMS Eric Norum
- EPICS on RTEMS John Sinclair
EDM using -ctl Michele Joyce
<2007>
2025
2026
<2007>
2025
2026
ANJ, 10 Nov 2011 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
